Alt 15.08.2005, 22:43   #1
appy
Benutzerbild von appy
Fahrzeug: 750Il Highline bwj 10/98
Standard Radio Splitscreen activieren.
hat jemand dies schon probiert und hat es geklappt?????
On 4/27/2005 Brian from the bimmerboard's navigation forum posted a sequence that he discovered which enabled his splitscreen radio mode. Following those steps, I was also able to enable this on my nav screen. The steps involved require that the nav OS be downgraded and then upgraded, so this will change your mode from feet to yards and also eliminate the accept screen. My unit was already in this mode, so that was of no concern to me.
I started at V25. This is the sequence I used for the downgrade to V24:
1. Turn the car key to the position that turns on the accessories (radio, nav, etc.), but does not start the car.
2. Turn off the radio.
3. Remove the nav map DVD.
4. Insert the nav software CD V24.
5. Wait for SW upgrade to complete, eject the SW CD, and show the "OK" to continue screen.
6. Remove the software CD and insert the nav map DVD.
7. Click OK.
8. While the nav system was rebooting, I turned the radio on.
9. When the nav screen came up, I turned the radio off, and then back on again.
Once the downgrade was complete and the radio splitscreen functions verified as working, a normal upgrade back to V25 was performed.
Ich werde das morgen abend versuchen anhand diese anleitung mal sehen ob das funkt.
Aber wen jemand das schon gemacht hat dan bitte die erfahrungen posten.
gr. Appy
appy ist offline   Antwort Mit Zitat antworten
Frage zum Radio BMW Bavaria C Professional RDS BayernRider BMW 7er, Modell E32 7 02.04.2012 15:01
Elektrik: Pfeifen im Radio tntx BMW 7er, Modell E32 17 01.03.2009 18:24
Neues Radio, gleiches Problem-ich habe s satt! mays_7er BMW 7er, Modell E38 26 27.02.2008 16:57
Elektrik: Radio Aufrüstung auf Pro gelungen cesa1882 BMW 7er, Modell E38 5 28.07.2004 11:31
Radio Probleme. guschtl BMW 7er, Modell E32 5 14.04.2004 09:43
Alle Zeitangaben in WEZ +1. Es ist jetzt 07:31 Uhr.
