06.12.2007, 22:33
Ab wann wurde der Filter verbaut? Habe BMW 750i Bj.03/90, habe ich denn gar keine Filter, oder wie sieht das aus?
Mfg Kay Solterbeck
06.12.2007, 23:24
750i powered by ROTTALER2
Mfg Kay Solterbeck
hallo kay
ich habe einen 89er fuffi, der hat keinen, mein 91er 730 hat ihn.
wann genau er eingeführt wurde,kann ich dir leider nicht sagen.
wenn du einen haben solltest,hast du aber einen aufkleber im handschuhfach.
viele grüsse
peter
so sieht der aus
07.12.2007, 08:44
hier ist es "amtlich"
Group 64 64 20 92 (3691) Woodcliff Lake, NJ December 1992
Heating and Air Conditioning Product Engineering
SUBJECT: Air Conditioning Microfilter Introductions
MODELS: All Except E30
Situation: Several inquiries have reached BMW regarding the introduction dates of the electrostatically charged microfilter. All vehicles produced 9/91 or later (except the E30) are equipped 100% with the microfilter. In addition, all E31 vehicles have been equipped 100% with two microfilters since their start of production.
Vehicles with the microfilter are supposed to have a red "Maintenance Reminder" decal in the glove compartment. However, on vehicles produced during 9/91 - 5/92, many of the labels were inadvertently left off. These vehicles are, however, equipped with a microfilter. Refer to S.I. 64 12 92 (3632) for further information on the microfilter decal. Some vehicles produced prior to 9/91 may be equipped with a microfilter, and can be positively
identified by the presence of the "Maintenance Reminder" decal in the glove compartment.The procedure for removal/installation of the microfilter element is contained in all current Repair Manual microfiche. For information concerning typical microfilter replacement intervals and filter capabilities, refer to S.I. 64 06 92 (3518) .
Note: This information supersedes all other information on microfilter introduction dates.
Group 64 64 12 92 (3632) Woodcliff Lake, NJ September 1992
SUBJECT: Microfilter Information Label Missing
MODELS: All except E30
Situation: Vehicles with air conditioning and the electrostatic microfilter (all U.S. vehicles produced
from 9/91, except E30) normally have a red decal in the glove compartment. However, during 9/91 - 5/92 production of vehicles, many of the labels were inadvertently left off.
Note: The microfilter information decal in the vehicle glovebox will be black in color starting from 5/92 production. The illustration below approximates the size and appearance of the newer decal:
Affected Vehicles: All models (except E30) produced from 9/91
through 5/92. Solution: When the microfilter requires replacement, make certain that vehicles in the affected production range have the microfilter information decal installed in the glovebox. The decal will be either red or black in color, and installed on the flat surface next to the orange SRS (airbag) label. If the decal is missing, and the car is microfilter equipped (produced from 9/91), the decal should be added in the glovebox on the flat surface next to the orange SRS label. A decal will be shipped in the same package with the replacement microfilter. Parts Information: A decal will be shipped in the same package with the replacement microfilter. Note that if the vehicle already has the decal in place, the dealer should save the extra new decal for use on other vehicles which might have the decal missing.
These decals will not be made available from BMW Parts at this time.
Warranty Status: Information only.
07.12.2007, 14:01
Das hei't ich habe keinen Mikrofilter, mein Handschuhfach sieht ganz anders aus, diese Abdeckung habe ich nicht mit dem Aufkleber bzw. den Aufkleber nicht. Was filtert den bei mir die Luft?Mfg Kay Solterbeck
Deine Lunge und sonst nichts
09.12.2007, 22:20
Liebender & Geplagter....
Fahrzeug: E32-750iLA (ProdDate 22.12.1988) 300tkm
Es gibt unter dem Wischwassertank einen schwarzen Zylinder (waagrecht eingebaut, Schlauch vorne und hinten dran). ich denke mir hat mal jmd erzählt das wäre was fürs Klima-Luft filtern... kann dann ja so eigentlich nicht sein
was ist das dann da für ein Teil?
so much music...
so many books...
... and just a lifespan of time
10.12.2007, 02:19
Ja, da wird auch geatmet, aber vom Tank
Da sind die Breather Valves davor (uebersetzt Atmungsventile) und dann geht das Benzin/Luftgemisch in den schwarzen Kohlefilter (das ist der, den Du meinst) und dann durch die Ruecklaufleitung zum Tank zurueck. Vorher mach das Zeug beim meinem Highline noch eine kleine Ehrenrunde durch die Kuehlleitung der Klima und wird runtergekuehlt von den heissen Temperaturen im Motorraum, bevor es wieder in den Tank zuruecklaeuft.
Hybrid-Darstellung
