23.11.2006, 07:28
Fahrzeug: E34 525i Touring
[E38] Himmel mit sunroof
Endschuldigung fur das Engels. Meinem Deutsch ist ganz schlecht.
A friend of mine has an E38 740i from 1996 with sunroof.
We are changing his interieur with another color.
But to change his headliner, we have also have to change his sunroof parts.
But we can't get his sunroof out.
Does anyone have tips, tricks an pics on how to remove the headliner and sunroof?
Greetz.
23.11.2006, 09:26
Fahrzeug: MB CL AMG
Hey guy,
no fear of asking questions in English!
Although some users don't even want to write here a properly German  .
To your problem:
drive the sunroof on the heave position. Then you dismantle the lateral disguising. Behind the disguising you will see on every side screws...and that's it!
23.11.2006, 09:34
I can read a bit German.
But writing German is a crime for me
How do you dismantle the lateral disguising?
23.11.2006, 09:44
Fahrzeug: MB CL AMG
...But writing English is a crime for me...
That applies to me  .
Habe ich vergessen zu fragen: hast Du ein Glasschiebedach oder ein Stahlschiebedach?
23.11.2006, 09:48
Es geht um einem Stahlschiebedach.
As you can see... I can do it a little bit!!
23.11.2006, 10:10
Fahrzeug: MB CL AMG
Öffne das Schiebedach ~15cm.
Dann kannst Du zwischen die Schiebedachverkleidung und das Schiebedach sehen, dort ist die Schiebedachverkleidung befestigt.
Löse die Befestigung.
Anschließend kannst Du die Schiebedachverkleidung weiter auffahren und somit das Stahlschiebedach demontieren.
23.11.2006, 10:28
I will try tonight!
Thnx!
08.12.2006, 06:53
We were not able to get it lose...
It's a Steel roof.
Which of both innerlinings have to go lose wirst? the one attached to the sunroof or the one that slides back?
it is very annoying!!
Driving around with a sandbeige innerlining and grey sunroof innerlining...
