Alt 04.01.2012, 00:43   #7
Hi Martin
I answered already the questions you sent me by U2U.
Basically all is answered already by the various users here in this thread.
Excerpt:
-besserer Leerlauf - better idle
-spontanerer Gasannahme - better throttle response
-besserer Durchzug aus dem Drehzahlkeller-better torque/acceleration from lower RPM range
GANZ WICHTIG-Wenn die Nadel bei 260km/h steht,dreht er immer noch weiter Und das mit 255er auf der VA und 285er auf der HA....
very important: when the speed indicator shows 260 kmh, it still goes higher, and that with 255 wide tires on the front axle and 285 tires on rear axle
others also comment that a bit fuel savings is possible under same driving style.
In Germany they basically nowadays only sell socalled super gasoline = 95 RON, 'normal' is almost not available.
Octane ratings in different countries
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Octane rating - Wikipedia, the free encyclopedia
Germany: "Super E10" 95 RON and "Super Plus E5" 98 RON are available practically everywhere. Big suppliers like Shell or Aral offer 100 RON gasoline (Shell V-Power, Aral Ultimate) at almost every fuel station. "Normal" 91 RON is only rarely being offered, because lower production amounts make it more expensive than "Super" 95 RON, so it is often not offered any more. Due to a new European Union law, gas stations are being required to offer and sell a minimum rate of the new mixture of "Super" 95 RON with up to 10% Ethanol branded as "Super E10" since early 2011. Due to that process the big suppliers are discontinuing the average "Super E5" 95 RON with <5% Ethanol so cars without the capability for using E10 need to use 98 RON petrol instead.
404 Motronic chip fits on (always check your data before ordering):
BMW E31 840i/Ci M60B40 V8
BMW E32 740i/iL M60B40 V8 (da passt auch der Getriebechip Bosch -263) = trans chip 263 fits on this car
BMW E32 730i/iL M60B30 V8 mit Bosch Nr. 0261200404 und Getriebechip -263
BMW E34 540i/iA M60B40 V8
BMW E34 530i/iA M60B30 V8
jeweils nur fuer die MOTRONIK Bosch # 0261200404
does NOT fit on:
nicht fuer MOTRONIK Bosch # 0261200484 , die ab Modelljahr 1995 mit der EWS II verbaut wurde.
The transmission chip ONLY fits on E32 740 with 5HP30.
What has been changed? Here the general comment of a known tuner "Conny" in Germany to Motronic chips from this time frame/built years:
Die DME (Mo-tronic) steuert Einspritzung + Zuendung, darum hat man sie Digitale-Motor-Elektronik genannt.
Motronic controls injection and ignition
Im Gegensatz dazu die Je-tronic, die steuert NUR die Einspritzung.
JETRONIC only controls injection
Die Einspritzdauer + die Zuendwinkel sind in Kennfeldern abgelegt und werden je nach Drehzahl und Gaspedalstellung abgerufen, mehr nicht.
injection time + ignition are programmed and are used depending on RPM and throttle pedal position
Kaltlauf-Faktoren, temperaturabhangige Leelaufdrehzahl, etc. werden aus einer Kennlinie abgerufen.
cold starting factors, temperature dependent idle RPM etc are in a Kennlinie/characteristic curve and used accordingly
Die Motronic kann leider nicht mehr, als Zuendung und Einspritzung regeln
The MOTRONIC can do nothing else than ignition and injection timing
Yor car is a 740i E32 (11.92). So it should have the 404 Motronic and the 263 transmission.
Was wohl aus dem Traum-760Li individual aus der BMW Welt wurde? Alfred G BMW 7er, Modell E65/E66 5 30.11.2008 15:29
Tuning: War auf dem Leistungsprüfstand!!!Rottaler2 Chips 7er_Fan BMW 7er, Modell E32 55 01.07.2008 13:04
Mein neuer 740i aus dem Land des neuen deutschen Meisters :) sunny Mitglieder stellen sich vor 3 23.06.2007 16:46
Gruß aus dem Land Brandenburg V12ausLDS Mitglieder stellen sich vor 1 25.01.2007 21:15
Halli Hallo.Verstärkung aus dem OS Land Kimble Mitglieder stellen sich vor 24 21.09.2004 10:03
Alle Zeitangaben in WEZ +1. Es ist jetzt 09:51 Uhr.
