Alt 23.11.2006, 07:28   #1
Green Hornett
Fahrzeug: E34 525i Touring
Standard [E38] Himmel mit sunroof
Endschuldigung fur das Engels. Meinem Deutsch ist ganz schlecht.
A friend of mine has an E38 740i from 1996 with sunroof.
We are changing his interieur with another color.
But to change his headliner, we have also have to change his sunroof parts.
But we can't get his sunroof out.
Does anyone have tips, tricks an pics on how to remove the headliner and sunroof?
Greetz.
Green Hornett ist offline   Antwort Mit Zitat antworten
Alt 23.11.2006, 09:26   #2
Jan
Fahrzeug: MB CL AMG
Hey guy,
no fear of asking questions in English!
Although some users don't even want to write here a properly German .
To your problem:
drive the sunroof on the heave position. Then you dismantle the lateral disguising. Behind the disguising you will see on every side screws...and that's it!
Jan ist offline   Antwort Mit Zitat antworten
Alt 23.11.2006, 09:34   #3
Green Hornett
I can read a bit German.
But writing German is a crime for me
How do you dismantle the lateral disguising?
Alt 23.11.2006, 09:44   #4
Jan
Fahrzeug: MB CL AMG
...But writing English is a crime for me...
That applies to me .
Habe ich vergessen zu fragen: hast Du ein Glasschiebedach oder ein Stahlschiebedach?
Alt 23.11.2006, 09:48   #5
Green Hornett
Es geht um einem Stahlschiebedach.
As you can see... I can do it a little bit!!
Alt 23.11.2006, 10:10   #6
Jan
Fahrzeug: MB CL AMG
Öffne das Schiebedach ~15cm.
Dann kannst Du zwischen die Schiebedachverkleidung und das Schiebedach sehen, dort ist die Schiebedachverkleidung befestigt.
Löse die Befestigung.
Anschließend kannst Du die Schiebedachverkleidung weiter auffahren und somit das Stahlschiebedach demontieren.
Alt 23.11.2006, 10:28   #7
Green Hornett
I will try tonight!
Thnx!
Alt 08.12.2006, 06:53   #8
Green Hornett
We were not able to get it lose...
It's a Steel roof.
Which of both innerlinings have to go lose wirst? the one attached to the sunroof or the one that slides back?
it is very annoying!!
Driving around with a sandbeige innerlining and grey sunroof innerlining...
Ami-e23 im Himmel hossomat BMW 7er, Modell E23 6 02.10.2006 08:03
MID im Himmel eingelassen warp735 BMW 7er, Modell E38 10 06.02.2006 16:36
Elektrik: Central Locking/Windows/sunroof inoperative Tech Bulletin Erich E32: Tipps & Tricks 4 12.04.2005 05:23
der himmel auf erden.... CoMBaT Autos allgemein 0 21.12.2004 11:03
Problem mit dem Himmel denitzo BMW 7er, Modell E32 4 05.08.2002 22:18
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:43 Uhr.
