Alt 22.06.2005, 14:56   #1
EmilC
Fahrzeug: bmw 735I (E32) 92, 730IA (E38) 94, 735li (E66) 95
Standard how to change language
Hey all..
i have a bmw e38 730 94. and i want to change the language from German to English. do anyone now hav to change the language? plz help me
EmilC ist offline   Antwort Mit Zitat antworten
Alt 22.06.2005, 15:07   #2
The Stig
Some say...
Benutzerbild von The Stig
You have to activate the extended Information in your BC.
1. Start ingnition. (position two)
2. Press Right Button(Check Control) in rhe Cockpit and hold until "Check Control OK" appears, short time after appears "Test Nr.01"
3. Press left Button.
Vin Code of your Car appears. The 5 Numbers have to be added. Note this Number ( i.e. AB12345 is added = 15)
4. Press right Button until "Test Nr.19" appears.
5. Press left Button as often as the added Number is (here 15 times).
6. Press again right button.
Now you have got access to the tests 03-21.
If you made any mistake, so at Test 03 - 21 only you can read "Lock:ON"
Test number 10 is Land/Sprache (Country/ Language) (0=Germany, 1=UK, 2=USA, 3=Italy, 4=Spain, 5=Japan, 6=France, 7=Canada, 8=Australia)
I hope you understood everything I tried to explain!
Alt 23.06.2005, 11:20   #3
EmilC
i have now undlock the obd but it is not possible to change from 0=german to english... why?
Alt 23.06.2005, 11:43   #4
Franz3250
Taxifahrer
Benutzerbild von Franz3250
Fahrzeug: S211
Because you can't modify it. It's only possible with a DIS from BMW.
Greets
Franz
(Murphy)
Alt 23.06.2005, 11:44   #5
JB740
the Senior :-)
Benutzerbild von JB740
Fahrzeug: 740i, Bj 03/17
Standard Emil
why don't you just try the easy way:
main Menu
Einstellungen
Sprache
now you can change to english or french, at least for the text indicated
regards jürgen
if you are trying to change the voice giving instruction in the navigation mode
let me know, I'll try to find the trick
Alt 23.06.2005, 19:28   #6
EmilC
my model is a e38 730 without a nav and dis..i understand that the only way to changde the language is if i have those thing, if not this is not possible?
Alt 23.06.2005, 19:49   #7
Janos 728
Benutzerbild von Janos 728
Fahrzeug: e46 320d Touring FL
only with BMW Diagnostic Tool. (GT-1, DIS-plus)
Janos
Janos 728 ist offline   Antwort Mit Zitat antworten
Alt 23.06.2005, 19:56   #8
EmilC
what is it and where can i get it from?
Alt 24.06.2005, 07:32   #9
Franz3250
Taxifahrer
Fahrzeug: S211
Ask your local BMW-Dealer. He has the technical equipment.
Greets
Franz
Alt 24.06.2005, 07:50   #10
WSE
Fahrzeug: E38 730d
You could buy a GT-1 from Central Lettershop for 17 500$...
WSE
WSE ist offline   Antwort Mit Zitat antworten
Oel-Analyse Erich BMW 7er, allgemein 2 09.02.2004 18:51
Like to change thelanquage to the voice control?! moriz202 BMW 7er, Modell E65/E66 11 17.01.2004 13:49
Can you change speakers when you have DSP? B12 5.7 Lang BMW 7er, Modell E38 3 28.04.2003 06:13
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:53 Uhr.
