Alt 12.12.2007, 03:02   #11
sunny_j_canada
thanks goofman.... the Canadian and usa spec cars come with the video feature disabled in the front. when i go to entertainment my options are FM, AM, WB ( weather channel ), CD, CD Changer & Memory. so im wondering how i can enable the video feature. i have the rear entrainment system with the dvd & TV tuner. they both work great in the rear. im not worried about the picture muting once in motion.
Thanks in advance
sunny_j_canada ist offline   Antwort Mit Zitat antworten
Alt 12.12.2007, 06:11   #12
Goose
Benutzerbild von Goose
Fahrzeug: 730d aus 09/2006
Thre rear entertainment system you have, it is with one Monitor in the middle or did you have two Monitors (one in each seat)?
Jegliche Rechtschreib- und Grammatikfehler sind beabsichtig und unterliegen dem Copyright des Verfassers.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.)  >>>PIXS von der Goose-Station AR-2000 (Hauptsys)<<<
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.)  >>>PIXS von der Goose-Station CS-601 (Zweitsys)<<<
Goose ist offline   Antwort Mit Zitat antworten
Alt 12.12.2007, 06:21   #13
sunny_j_canada
in the middle. controlled by the rear idrive
Alt 14.12.2007, 02:41   #14
sunny_j_canada
anyone have any idea's?
Alt 15.12.2007, 23:50   #15
tbeyer
Benutzerbild von tbeyer
Fahrzeug: 735i (E65), MB SL 320 (R129), 525tds (E39)
Just a weird thought: do you know anyone who has access to BMW's coding computers? If so: try changing your car config to be a European car, then check, whether your front screen works. If it does (which I would imagine) then check whether you can switch on the canadian options (whatever they might be) manually. If all fails, switch your car back to US/North America.
Just a thought, might not work or be possible. Someone who might be able to help here, too is user appy or RolandDV. They are online regularily.
cheers
Torsten
Ich bin ein gefährlicher Signaturvirus - kopier mich in alle Deine Mails!
tbeyer ist offline   Antwort Mit Zitat antworten
Alt 16.12.2007, 01:32   #16
weltspion
Fahrendes Mitglied
Fahrzeug: E65-750i (10.2007) / Porsche 911 (04.92) / MB W116 (01.74) / MCC Smart ForTwo
Hi Sunny!
It's a off topic, but the white Alpina B7 on your website is actually awesome.
Cheers,
Torsten
weltspion ist offline   Antwort Mit Zitat antworten
Alt 17.12.2007, 21:33   #17
sunny_j_canada
its going to be hard to find someone that would be able to do coding but ill look into that thanks.... the white Alpina B7 pictures i found here on the Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.7-fourm.com
Alt 26.12.2007, 01:00   #18
Ellemeet
Benutzerbild von Ellemeet
Fahrzeug: 750Ldx '13 m sport, Volvo V70-II T5 ; A5 Cabrio 3.0tdi quattro 2013; Landrover Discovery 4 3.0SDV6 HSE
Hi
your problem is that you do not have a TV tuner. This is the option you need to give an output.
Basically there 3 ways to get an external picture on your front screen:
- use the onboard tv tuner (if available): it has a rearcamera input you can use (however no sound input!)
- use an interface that will act as a tv tuner (like diets IMU 1550 or Tixxon.de). Your dealer will have to program the car as if a tv tuner is installed >> sound input is included!!
- use an interface which overrides the onboard system (still no sound)
Ellemeet ist offline   Antwort Mit Zitat antworten
Alt 26.12.2007, 01:13   #19
sunny_j_canada
Zitat von Ellemeet Beitrag anzeigen
Hi
i have the tv tuner. i can watch and control the tv and dvd through the rear idrive and rear screen only. the cars in europe have the video feature in the front idrive and the canadian and usa cars dont. any help is appreciated.
Alt 27.12.2007, 13:12   #20
rubin-alt
Fahrzeug: suche e39 M54
try du buy a german tv-tuner or ask Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Carsolution to reprogramm the software in your tv-tuner to a german-version
Wide Screen Speltz BMW 7er, Modell E38 9 22.03.2007 13:31
jap. Highline in Canada Erich eBay, mobile und Co 4 08.04.2006 01:13
7er goes to Canada - ich sach Tschüss! TJ BMW 7er, Modell E32 11 01.03.2006 10:05
Split Screen a_engels BMW 7er, Modell E38 16 04.09.2005 22:30
Alle Zeitangaben in WEZ +1. Es ist jetzt 13:55 Uhr.
