Modell E65/E66 |
29.04.2005, 06:08
#21
Fahrzeug: 730d aus 09/2006
Zitat von Goose
Für was geht denn der original Halter über den Tisch?
Das wäre dann mal interessant
17.11.2005, 18:46
#22
Does anyone know what it takes just to install the board monitor so it will work along with the front monitor on DVD/TV?
I have a complete fond monitor and control box as well. I would like to know what cables etc. I need to install it?
17.11.2005, 18:48
#23
Kombinator auf Zeit
Fahrzeug: F25 xDrive 30d 09/12, E39 530dA 09/03
Was
Man kauft mit Geld das man nicht hat,
Sachen die man nicht braucht,
um damit Leute zu beeindrucken die man nicht mag.
17.11.2005, 18:53
#24
Sorry I don't speak German...
17.11.2005, 20:20
#25
Fahrzeug: F01
ohhhhh
Hello Erik,
the problem is, that you not only need the Monitor and the Videoboard - taht´s the little box with the rips which is located behind the Middleconsole - you also need a twin-Video-module and the rear-iDRIVE button and the conection-cables to drive the rearmonitor.
http://www.geocities.com/telescopeman97/E65.html
http://www.geocities.com/telescopeman97/BMW745.html
The second choose would be, to change the original TfT display against a 7" PAL/NTSC display (PAL=fbas) - so you only need a KOAXcable from the TfT to the orig. BMW Video-module in the trunk and you can watch TV or DVD.
greetings
Alexander
17.11.2005, 21:24
#26
Hi Alexander,
As I wrote U2U I do have the video control module and the fond monitor, but I have no idea of what cables to use etc.
However I think I would be satisfied with just doing what you suggest. What did you do? Did you use another monitor? And if yes which one did you use? Also I would like to know which coax cable you used, and how/where you connected it to your BMW TV/video module?
