Alt 03.05.2015, 20:24   #1
Angelus669
Fahrzeug: E66-760LIA (09.03)
Standard Ticking noise bmw 760 lia e66
Hi everybody,
First of all, i'm sorry i don't speak german (i'm french), that why my post will be in english. I've an issue with my bmw 760LIA and i don't find a solution.
Some weeks ago, i had a misfire on cylinder 8 and in the sametime, a ticking noise appear on the drive side bank.
I took my car to the dealer, i decided to change all spark plug and all ignition coil - - > result misfire still present and ticking noise too
But the problem is that, i still have the strange ticking noise, moreover, this noise appear only when the motor is at operation temperature (warm).
When this noise appear, i have some sputter on my exhaust and when i'm driving, i have some hole in acceleration, it's very boring !
I don't have issue when the car is cold !
Do you have any idea of my issue because i don't know what to do
Please find below the ticking noise on the video :
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://youtu.be/Jf_Vd3p_6RQ
The error code on the soft diag is :
274B : Misfire detection cyl 8
274E Misfire detection, Checksum failure
I don't understand why i have this issue only when the engine is at warm temperature.
Angelus669 ist offline   Antwort Mit Zitat antworten
Alt 03.05.2015, 20:45   #2
I think, you should change the Spark coil / ignition coil on Cylinder 8
Alt 03.05.2015, 20:49   #3
Angelus669
Thank you for your answer.
Like i said before, the 12 spark plug and the 12 ignition coil are new (less 300km).
Currently, i'm unmount the intake manifolt, i will swap coil/plug with other cylinder, just for test.
750 LiA v. 5/2012 Vorserie Modellpflege kaufen? oldi-ol BMW 7er, Modell F01/F02 9 22.12.2014 17:11
BMW-Individual: BMW 760 Li Sterling retovonwartburg BMW 7er, Modell F01/F02 2 31.10.2013 14:00
Motorraum: VANOS noise fixed.......but another problem. Glacier BMW 7er, Modell E38 11 20.03.2011 19:18
General question + noise -> in the trunk Maarten730 BMW 7er, Modell E32 7 05.04.2009 18:41
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:52 Uhr.
