Alt 31.10.2008, 19:40   #1
silver50
Fahrzeug: 2006 730d Sport
Standard Anyone do English ??? Cannot find Answers
Greetings from Edinburgh, Scotland.
Searched other forums but I just cannot find help for these questions!
I am desperate to upgrade my hi-fi system. I used to have Logic 7 Professional in 745i
Here at 7er Forum is where answers are. I have a 2006 730d Sport
1. I have Basic "BMW Speaker System" NOT "Hi-Fi Speaker System" Do you know excactly how front speakers are wired regarding the under seat woofers? I am thinking about fitting Blaupunkt "PnP" Amplifier and want to know if the under seat woofers run independently from my CCC player or if there is just one left/one right speaker cable from CCC.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.blaupunkt.com/uk/7607792132_main.asp
2. I have heard the speaker cable is in place in each rear door. If so, can I find these cables in trunk/boot(maybe where amplifier for Logic 7 is???)
3. Any help or suggestions for upgrading basic stereo in E65 much appreciated!
Many Thanks
silver50 ist offline   Antwort Mit Zitat antworten
Alt 07.11.2008, 22:46   #2
pfunde
Fahrzeug: G12-M760iL 2017
I would search some of the US based forums. I know thar here in Denmark it's something like 3000£ to upgrade speakers and amp's, but i'm not sure that uoy can add logic 7
pfunde ist offline   Antwort Mit Zitat antworten
Alt 07.11.2008, 23:17   #3
PIT M3
Benutzerbild von PIT M3
Fahrzeug: E61 530xdAT
Hi silver50,
as much as I know, there is a little amp (with cooling fins) in the trunk, left hand side ...
This amp is only for powering the subs under the front seats - the mid speakers and tweeters are powered from the ASK, located in the central console.
Wiring will be independently !
Do you have more detailed informations about the Blaupunkt PnP system?
I can´t imagine, how this will work ?
Regards Peter
E65 verkauft...
Niveau ist keine Gesichtscreme..
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bmw-syndikat.de/bmwsyndik...TOPIC_ID=11249
PIT M3 ist offline   Antwort Mit Zitat antworten
Alt 07.11.2008, 23:59   #4
silver50
Zitat von PIT M3 Beitrag anzeigen
Hi silver50,
Regards Peter
The car's that have the small amplifier actually have what BMW call "hi-fi speaker system," my car just has the most basic system which seems to run the woofers underneath the drivers and passenger seats along with the front door speakers.
I have found out this week that the wiring splits near to the woofer under seat- part goes to the front door the other part to the woofer.
There are several amplifiers to chhose from with blaupunkt PnP the THA-555 seems the best. See link on this page for wiring harness adapters.
I think this system will still work for car's with "hi-fi speaker system," as it will not affect the signal to the amplifier in boot/trunk but will allow more power to front doors/rear parcel shelf speakers, and depending which Blaupunkt amp you choose will allow expansion further for your system.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Blaupunkt - Amplifiers - THA-Series - THA 555 PnP
Alt 08.11.2008, 00:05   #5
silver50
Here is a photograph of PnP Harness. I can see it is designed for latest BMW CD/CCC etc.
It basically runs all 4 speaker level inputs to the Blaupunkt Amplifier (high level) and back to the wires going to the speakers. It is supposed to also provide +/- and switch to Amplifier.
This system will obviously NOT work with Logic 7 soundsystem.
Dateityp: jpg h023PNP016-f.jpg (60,1 KB, 8x aufgerufen)
Alt 08.11.2008, 00:09   #6
silver50
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Blaupunkt Deutschland - Der Pluspunkt im Auto.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Blaupunkt - Verstärker - THA-Serie - THA 555 PnP
Alt 13.11.2008, 22:09   #7
PIT M3
This PnP Harness will not work in the E65 series ...
The connections seem to be completely different - on my point of view, the only chance is to work with regular high / low adapters, by cutting the speaker cables.
Furthermore the E65 audio system has no regular + switch in the audio system (activation by bus system)
Regards Peter
Alt 13.11.2008, 22:36   #8
silver50
Hi Peter,
Certainly Blaupunkt list the E65 as included for a harness although I would not like to have problems with it. I actually contacted Blaupunkt for confirmation, but I still remain only 90% convinced!
I just took this picture of the rear of a mini-disc unit for the E65. It does look as though it will fit the harness(previous picture)except it looks as though the optic connections are on the opposite side.
I agree it may be better to just pick up the speaker cables and run them into a line level convertor and not bother with the Blaupunkt harness. There are good points and bad points about using it.
Dateityp: jpg BMW ASK-MD.jpg (27,3 KB, 6x aufgerufen)
Dateityp: jpg ebay 001.jpg (46,5 KB, 6x aufgerufen)
Karosserie: AHK (english) amuso BMW 7er, Modell E32 14 21.02.2007 09:17
Elektrik: bordcomputer checkontrol english moses088 BMW 7er, Modell E38 5 07.09.2006 01:16
English speakers-can you help again? silver50 BMW 7er, Modell E65/E66 1 28.07.2006 08:16
Speak English?? Question Please silver50 BMW 7er, Modell E38 10 10.02.2006 01:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 01:26 Uhr.
