10.05.2015, 23:14
Fahrzeug: E32-735i dec 1986
Oil cooler
Hi all.
I have a little trouble with my oil cooler.
So, if I disconnect the oil cooler hoses from my oil filterhousing and I close the holes with a plate. Can I run my car (735 from 1986 ) like this for a while. I mean, will the oilpump still be able to pump the oil trough the whole system.
I know there were models without an oilcooler but maybe they also had a different oilfilterhousing.
No need to reply in English.
Thanks Henk.
10.05.2015, 23:21
Fahrzeug: e38 740i FL-04/99
Geändert von boxerheinz (10.05.2015 um 23:28 Uhr).
11.05.2015, 10:51
hi Boxerheinz.
Thanks, but it's not about the oilfilterhousing. I want to disconnect the oilhoses from the oilcooler and I like to know if the oil circulation through the engine will be blokked if I do so.
Henk.
11.05.2015, 11:21
As it is now with you you need a circuit to the motor.
It is only then when the housing is also changed by the oil filter.
11.05.2015, 12:14
Hi boxerheinz.
write it in German.
Thanks Henk.
11.05.2015, 12:20
Beim Ölfiltergehäuse mit Ölkühleranschlss ist es ervorderlich das der Kreislauf bestehen bleibt.
Hybrid-Darstellung
| Thema |
Autor |
Forum |
Antworten |
Letzter Beitrag |
Motorraum: Oil pressure
Beumers |
12 |
29.03.2015 16:41 |
Cooler HARTGE :-)
Raffael@735i |
eBay, mobile und Co |
13 |
18.08.2008 16:21 |
Lenkung: OIL für lenkunterstützung
Heffernan187 |
50 |
08.02.2008 20:02 |
Motorraum: Oil Filter
Rosemary |
6 |
06.05.2006 22:45 |
Elektrik: Oil Temparatur
Riverghost |
3 |
17.06.2004 12:58 |
