Alt 22.07.2007, 01:09   #1
malik22
Fahrzeug: E32 750il
How about the 740 V8 how does it compare to the other two?
malik22 ist offline   Antwort Mit Zitat antworten
Alt 22.07.2007, 17:05   #2
Bert730/6
Benutzerbild von Bert730/6
Fahrzeug: 520i Bj 1992
The 740 has nearly the same power as the 750, but it needs less fuel!
In general the 740 is more economical to maintain, than the 750.
Therefor the 750 has the smooth quiet V12 sound, which is simply fantastic.
Nevertheless the 6-cylinder-engines 730 and 735 are the ones, which are most dependable, and are easist to handle.
Bye from Germany
Bert730/6 ist offline   Antwort Mit Zitat antworten
Alt 22.07.2007, 19:12   #3
malik22
Fahrzeug: E32 750il
Thx for the help guys I know the V12 will be more expensive to maintain what i meant was does it give alot of trouble if i buy one whats the max km you guys would recomend when I buy a 750?
Alt 22.07.2007, 19:22   #4
dancingbalu
Fremdgänger mit Stern
Fahrzeug: Mercedes E430 LPG
@malik: you should ask peter becker or wait till he writes an answer here. he has much information about the V12 750 i think, and although he is a gentle person who helps very nicely.
sincerely yours
dominik
dancingbalu ist offline   Antwort Mit Zitat antworten
Alt 22.07.2007, 19:28   #5
peter becker
750i powered by ROTTALER2
Benutzerbild von peter becker
hy malik
read this link from erich, it´s very helpful to read this, if you want to
go to a 750.
the kilometer on the odometer ist not the big point, if the car was in
a good workshop. but if the owner before you igonred the regulary checks,
you can go in a lot of trouble.
best regards
peter
ps. this is the link from erich
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://kunden.tridem.de/auto/erich/K...e/kaufheng.htm
Alt 16.08.2007, 22:24   #6
malik22
Fahrzeug: E32 750il
Thx for the help guys I have been looking around and saw a E32 B11 3.5 240ps would this car be more expensive for maintenance then a 750 and can all bmw dealerships fix alpinas?
Alt 17.08.2007, 07:58   #7
pimphustler
Fahrzeug: F01 750i (09.2008)
Hello Malik,
even though I haven't had my car for very long, I have already found out that the most important thing to have when buying an old 7 Series is a good workshop that knows what it's doing at reasonable prices. A BMW dealership is definitely expensive and mostly doesn't even really know what it's doing with these old cars anymore. So if you plan to have your car serviced and/or repaired at a BMW dealership, it will be VEEEEERY expensive. If getting your car serviced at BMW is your only option, then I strongly recommend a car with as few cylinders as possible to reduce the already high costs you will run into...
Michael
pimphustler ist offline   Antwort Mit Zitat antworten
Alt 17.08.2007, 09:24   #8
malik22
Fahrzeug: E32 750il
Thx for the pimphustler do you know any good workshops here in Switzerland?
Alt 17.08.2007, 09:31   #9
pimphustler
No, sorry, but search in this part of the forum: Interner Link) http://www.7-forum.com/forum/rubrike...-werkstaetten/
735 vs. 750 ... ? 735 ... die heimliche Rakete ?? ReneausE BMW 7er, Modell E32 77 16.05.2006 13:45
Alle Zeitangaben in WEZ +1. Es ist jetzt 00:15 Uhr.
