Alt 19.04.2006, 16:42   #1
Nicholas
Fahrzeug: E32-730iL(08.93)
Standard PDC Frage (Auf Englisch)
Hallo! Ich heisse Nick und ich komme aus Australien. Ich verstehe viel deutsch, aber meine Sprachkenntnisse sind sehr schlimm. Ich werde meine Problem auf english beschreiben....
My car is 8/93 BMW 730iL (M60). I have a problem with my PDC. It is not functioning correctly. When I engage reverse the button "flashes" and I get a long (5 seconds) "peep" which according to the owner's manual - means the system is defective. The sensors do not function for either the front or rear of the car.
There is some very minor damage to the bumper bar (scratch marks) but none visible to the sensors themselves. I do not believe that the sensors are faulty.
Is it possible there is one or two faulty sensors that are causing the whole system to malfunction? Or is it something else?
I have tried asking at Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.bimmerboard.com and Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.roadfly.com (popular English E32 forums) but not many have PDC as they have American cars which didn't come with it.
Vielen Dank! Ich hoffe, dass Sie mich verstehen koennen.
Nicholas ist offline   Antwort Mit Zitat antworten
Alt 19.04.2006, 18:17   #2
flohl
Fahrzeug: 750iL (E32) Automatik,Baujahr 12.93
Hello Nicholas
My English is not very good
It is possibly that only a sensor is defective.
At the insert of the reverse gear asks the PDC if a long beep appears is a little defective.
The Peipton comes from in front sensor is in front defective.
The beep comes from behind sensor is behind defective.
In the framework place they can test which sensor is defective.
flohl ist offline   Antwort Mit Zitat antworten
Alt 19.04.2006, 19:07   #3
Nicholas
Standard The sound is different?!
So there is a "peep" and a "beep" depending if the fault comes from the front or the rear of the car. Peep = front and beep = back? Now how should I work out whether I am hearing a "peep" or a "beep" hahaha.
Alt 19.04.2006, 19:52   #4
flohl
Das PDC hat doch im Innenraum zwei Signalgeber welcher Piept wenn du das PDC einschaltest vorne oder Hinten
Ich antworte auf keine Frage mehr... Rottaler2 BMW 7er, Modell E32 116 03.01.2009 21:23
Elektrik: Problem mit Park-Distance-Controll (PDC) Sibbenner BMW 7er, Modell E38 49 13.03.2008 00:31
Innenraum: Cockpit Sprache auf englisch, mist Charly.1st BMW 7er, Modell E32 16 10.04.2006 12:44
Starkes "Rauchen" im Leerlauf (Wasserdampf?) Marek75 BMW 7er, Modell E32 6 04.12.2003 16:03
Fahrbericht BMW 530dA E60 JRAV Autos allgemein 19 30.09.2003 18:31
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:54 Uhr.
