14.01.2006, 15:28
Fahrzeug: golf 3 6
engine connector 25 pin
Can some one please help me i want to find a wiring diagram of the engine connector
its a round socket with 25 pin placed near the fusebox
i want to know where the 25 pin goes to
car is a e32 730i 1991 v6 engine
cant find this wiring diagram i sweden so had to try a foreign forum
maybe not the best explanation if u dont understand ask and i try to explain better
/martin
Geändert von timbertaz (15.01.2006 um 14:23 Uhr).
Grund: engine 25 pin connector
14.01.2006, 15:49
Have a look here under electronics, all by year produced
http://www.e38.org/e32/
14.01.2006, 17:53
Fahrzeug: golf 3 6
thank u i did look there yesterday and i did find the socket
but not a description of the pins
is it any one here that have a service manual ??
it starting to look like a impossible mission to find somthing about the placment of pins in this connector
Geändert von timbertaz (15.01.2006 um 14:21 Uhr).
15.01.2006, 14:21
Fahrzeug: golf 3 6
can some one please help me
at least tell me the right german name for this connector so i know what to serch for
15.01.2006, 14:43
Doppel Posting, sorry
Geändert von Erich (15.01.2006 um 14:58 Uhr).
15.01.2006, 14:57
Is it a V8 M60 or a straight 6 M30B30 (R6 in German) engine?
For the R6 I find 20 pins only under main group 12, subgroup 31.
http://www.realoem.com/bmw/partgrp.d...38&hg=12&fg=31
But also the V8 has only 20 pins as far as I can see.
http://www.realoem.com/bmw/showparts...27&hg=12&fg=31
Anyway, if you find on the spare parts catalog the number and the name in English, copy and paste the number into here and then you have the German name and the German price
http://www.pusches.de/preissuche.php
And this is the wiring harness for DME for V8
http://www.realoem.com/bmw/showparts...17&hg=12&fg=28
Just checked once more in the Bentley repair Manual. What you means is the main engine harness connector, which has 25 pins. On a 730 R6 it is near left front strut tower, on a V8 740 it is on the right cylinder head, beneath top engine cover. And on a 750 connectors are near left front strut tower.
Blue/yellow wire # 1 is for dynamic switch and blue/white wire # 2 is for static switch. for oil level sensor.
The others??
@Reinhard & all: hast Du die Farben und Bezeichnungen fuer der Stecker NEBEN der Diagnosebox fuer das Motormanagement, also Pin 1-25?
15.01.2006, 18:55
Fahrzeug: golf 3 6
its very hard for me te explain becouse its a friends car i havent looked at it and he lives far away from me but he cant use a computer
the car is a 730i with a straight 6 motor think its the one u call r6 M30B30
and the connector is placed near left front strut tower close to the fusebox
and he say to me that it has 25pin but not all of them are in use so maybe its only 20 pin
think ur right when u say main harness connector
i found som pics of the socket and the name of it was x20 sw or x21 sw
and some number i dont understand B260007.00
im not interested in the diagnostic but it looks the same
he is going to look for the colours tomorrow i hope and see if they matches with that u say
hope this help u som more and im very greatfull fore all the help u give me so far
vielen dank /martin
16.01.2006, 02:46
I think what you mean is besides the diagnostic socket lin on the right.
= engine harness connector. It is not mentioned here by name, but you can see it. Between the diagnostic socket and the fuse box the black round covered connection box. And there are 25 pins inside.
http://www.bmw7resource.co.uk/forum/...tach=100;image
16.01.2006, 07:45
X20 details for download
I got it from Javier, the electronics wizzard on bimmer.info
You can download it here
http://www.bimmer.info/forum/showthread.php?t=17794
@Rottaler2: Reinhard, siehe pins 17+21, die waren wohl gemeint bei meinem Problem limpmode.
17 TxD (Communications) weiss/violett DME X6000-55
21 ignition switch in run/start (also Zuendschluessel in Motor-an/Start- Stellung), Gruen, DME, X6000-27
16.01.2006, 10:36
† August 2007
Hi Erich
TXD weiss/violett geht an Pin 20 der Diagnosrbuchse D100 hab die Buchse angehängt.
Gruß Reinhard
