Alt 31.12.2019, 18:59   #1
NikolayNikolay
Fahrzeug: E32-730V8 (02.92)
Zitat von Erich Beitrag anzeigen
Maybe you post that question and the pics also here in the E31 forum where you already asked for the window switch button
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.bimmerforums.com/forum/s...tton-sun-blind
I moved the thread from WTB to the normal E31 discussion forum
yep, it's my post, how are you find it? I have bought this switch, but I no have a plug, because I want to install it in my e32, and second question: I have got an electro back curtain, but have no plug for curtains motor, and so I look for a number of it. : +
NikolayNikolay ist offline   Antwort Mit Zitat antworten
Alt 01.01.2020, 00:36   #2
I just searched with your user name there and found the old thread.
I have searched for you for the plug in the parts catalog, but so far I did not find it.
Edit, checked the plug under the panel of my friends car, it goes into the control unit for the sunshade, BMW Wiring Cable Plug Terminal Connector 4 Pin 1378141, new number 61131378141
AMP 963001-1
plug for switch of sunshade of e31 must be a 6 pin plug. No success so far to find that Steckergehäuse
Geändert von Erich (01.01.2020 um 10:01 Uhr).
Alt 02.01.2020, 00:04   #3
NikolayNikolay
AMP 963001-1
Thank you for you help) : верхняя
Alt 03.01.2020, 14:42   #4
The female plug for the E31 sunshade switch is 5 or 6-pin
3-2-1
6-5-4 (6 is no pin)
but it is not listed as single item in the E31 parts list, probably part of the complete wire loom.
The switch has the part number 61311383488
here is a picture of the plug with pigtail, but no part number can be seen
Looks like the same switch is used on E36
Alt 03.01.2020, 18:35   #5
NikolayNikolay
I got this answer on (bimmerforum) today: верхняя
Geändert von NikolayNikolay (03.01.2020 um 19:21 Uhr).
Alt 03.01.2020, 23:48   #6
yes, I know, I posted it, on your photo at left it is sunshade switch E31 and at the right it is a sunroof switch for e36. The shape of the plug is the same, the E36 sunroof switch has less male pins, so the plug will be the same but has some empty holes without connection. Check the parts catalog for E36 for this plug
Alt 04.01.2020, 01:34   #7
NikolayNikolay
I did it)catalogue bmw haven't 90% plug and in general parts for oldtimer(
Elektrik: Suche Steckernummer für Sitz-SG HeinrichG BMW 7er, Modell E65/E66 1 29.01.2014 01:17
Alle Zeitangaben in WEZ +1. Es ist jetzt 01:25 Uhr.
