Alt 07.10.2019, 20:27   #5
Beumers
Fahrzeug: E32-735i dec 1986
Hi Fufi.
I drove around for a while to make sure the water got hot enough. With the intake to the watervalves clambed of, the left vent at the front window got mildly warm. The rest of the vents were all cold. The wheels of the operating unit on the dash all on cold.
So I can drive arond with it without steaming out of the car. Keep in mind that it is allready oktober. I think it's strange. The only explanation I can think of is that the clamb is not completaly shut and lets trough a little bit of water.
No key in Ignition. Blower on Zero. I measured 0.35 Ohm between 1and2(Y/BR/PRP) and no reading between 1and3(Y/BR)
Blower on first position, no reading at all on both 1/2 and 1/3. No Ohm reading.
I'll try and wire pins 1,2and3 as you mentioned to find out if the water flow is stopped by the watervalves.
In the back of my mind I think I already tried this last year. ( Stopped working frustrated.)
Regards Henk.
Beumers ist offline   Antwort Mit Zitat antworten
Dimensions of Rear window shelf Serifus BMW 7er, Modell E32 3 28.03.2012 21:49
Webdesign/PHP/SQL: window.close funktioniert nicht mehr bei Meta-Refresh bommelmann Computer, Elektronik und Co 8 21.10.2008 07:28
BMW 8er: Rear quarter window removal procedure Erich Autos allgemein 0 26.07.2008 05:40
Innenraum: Fenster Vorhang-window Curtains GROF BMW 7er, Modell E38 2 11.06.2006 13:07
window sox anstatt Sonnenrollos Erich BMW 7er, allgemein 0 28.01.2005 15:08
Alle Zeitangaben in WEZ +1. Es ist jetzt 07:51 Uhr.
