Alt 06.10.2019, 20:22   #4
fuffi_lwl
Mitfahrendes Erglied
Benutzerbild von fuffi_lwl
To further check the electronics, do the following: Remove the connector and put a current of 12V on Pin 1. Put Pin 2 and 3 to ground, somewhere in the engine bay. This way, the water valves are shut off, so no warm water should enter the heater core, provided that the seals are in good condition.
Without current, the water valves are open, and thus the heater core always warm.
Pinout as follows:
Pin 1: supply voltage 12V
Pin 2: Ground for the valve on drivers side water circuit
Pin 3: Ground for the valve on passenger side water circuit
If the heating is getting cold after this procedure, the signals of IHKA and so on are wrong.
Geändert von fuffi_lwl (06.10.2019 um 20:31 Uhr).
fuffi_lwl ist offline   Antwort Mit Zitat antworten
Dimensions of Rear window shelf Serifus BMW 7er, Modell E32 3 28.03.2012 21:49
Webdesign/PHP/SQL: window.close funktioniert nicht mehr bei Meta-Refresh bommelmann Computer, Elektronik und Co 8 21.10.2008 07:28
BMW 8er: Rear quarter window removal procedure Erich Autos allgemein 0 26.07.2008 05:40
Innenraum: Fenster Vorhang-window Curtains GROF BMW 7er, Modell E38 2 11.06.2006 13:07
window sox anstatt Sonnenrollos Erich BMW 7er, allgemein 0 28.01.2005 15:08
Alle Zeitangaben in WEZ +1. Es ist jetzt 21:04 Uhr.
