Alt 19.05.2018, 14:10   #10
da der Link nicht mehr geht, hier kopiert:
Troubleshooting BMW A5S 310Z ZF 5HP18
Condition.... .....Cause.............. Remedy
Position Park position does not engage
a) Shift linkage between selector lever and transmission maladjusted
b) Excessive friction in parking lock mechanism
a) Adjust selector lever, refer to 24 00 007
b) Replace parking lock parts (connecting rod, pawl),refer to 24 34 006
Park position does not hold (slips)
Engine cannot be started in N or P, or can be started in all positions
b) Transmission switch faulty. Starter motor inhibit relay or power line defective
b) Replacing transmission switch, refer to 25 16 080. Replacing/repairing relay between inlet lines
Position R:No reverse gear
b) Clutch B destroyed
c) Brake D destroyed In this case also no engine braking effect in position 2,1st gear
d) Brake G destroyed
e) Refer to "Troubleshooting Valve Body"
b) Exchange transmission, refer to 24 00 046
c) Exchange transmission, refer to 24 00 046
d) Exchange transmission, refer to 24 00 046
Hard engaging jolt P-R or N-R
a) Idling speed too high
b) Refer to "Troubleshooting Valve Body"
a) Refer to Test Plan
Backup lights do not light up (electrics OK)
a) Transmission switch faulty
b) Shift actuation between selector lever and transmission incorrectly
set
a) Replace transmission switch, refer to 25 16 080
b) Adjust selector lever, refer to 24 00 007
Car moves or creeps
b) Clutch A defective (welded solid)
Position D: No power transmission
a) Clutch A destroyed
b) 1st gear one-way Gear defective
c) Shift linkage between selector lever and transmission maladjusted
a) Exchange transmission, refer to 24 00 046
c) Adjust selector lever, refer to 24 00 007
Hard shift impact N - D neng > 1500 rpm
b) Also refer to "Troubleshooting Valve Body"
a) Refer to Inspection Manual
No shift (warm or cold)
No shift: Shift 1-2
a) Brakes C1 and 2 faulty
b) Insufficient oil supply to brakes C1 and C2
Shift 2-1
Shift 2-3
a) Clutch F faulty
b) Insufficient oil supply to clutch F
Shift 3-2
Shift 3-4
a) Clutch E faulty
b) Insufficient oil supply to clutch E
No braking effect:Shift 4-3
a) Brake band C2 faulty; in this case shift 1-2 not OK
b) Insufficient oil supply to brake C2
No shift:Shift 4-5>>>Refer to "Troubleshooting Valve Body"
No shift:Shift 5-4>>>Refer to "Troubleshooting Valve Body"
No shift:Shift 5-4
Clutch A faulty, in this case no 1st ... 4th gear
Shift from full load to kick down too long
a) Plates broken
Engine spins in shift 2-1
a) Poor friction torque at plates
b) 1st gear one-way Gear not OK
a)b) Exchange transmission, refer to 24 00 046
Engine spins in shift 2-3/3-2
Engine spins in shift 4-3
b) 3rd gear one-way Gear not OK
Engine spins in shift 4-5/5-4
No engine braking effect, no manual downshift 5-4
a) Clutch A damaged
No engine braking effect, no manual downshift 4-3/3-2
a) Refer to "Troubleshooting Valve Body"
No 1st gear, no braking action
a) Brake D faulty
a) Replace converter, refer to 24 40 006
No converter lockup clutch
a) Torque converter faulty
Engine dies when moving off in Drive (converter lockup clutch always engaged)
No positive engagement in forward or reverse
a) Driver pressed off impeller
Noise: Noise in all positions
a) ATF level too low
b) Valve body leaks
c) Oil strainer dirty
d) Round seal on oil filter missing/faulty
a) Correct ATF level, refer to 24 00 026
b) Replace valve body, refer to 24 30 006
c) Replace oil strainer, refer to 24 31 156
d) Replace round seal, refer to 24 31 156
Leaks Oil dripping from converter bell housing
a) Round seal on oil pump body leaks
b) Round seal on pump body leaks
c) Radial oil seal for converter leaks
a) Replace round seal, refer to 24 31 020
b) Replace round seal, refer to 24 31 020
c) Replace radial oil seal, refer to 24 31 020
Leak between transmission case and oil sump
a) Mounting bolts loose
b) Gasket faulty
a) Tighten bolts. For tightening torque, refer to Technical Data
b) Replace gasket, refer to 24 11 008
Leaks Output leaks
a) Radial oil seal for output flange leaks
b) O-ring for transmission extension leaks
a) Replace radial oil seal, refer to 24 12 016
b) Replace O-ring, refer to 24 12 016
Manual shift valve shaft leaks
Radial oil seal faulty
Replace radial oil seal, refer to 24 12 106
Transmission plug leaks
a) Plugs loose
b) Seals faulty
a) Tighten plugs For tightening torque, refer to Technical Data
b) Replace seals
Oil cooler pipes leak
a) Oil cooler pipes loose
b) O-rings faulty
a) Tighten oil cooler pipes. For tightening torque, refer to Technical Data
b) Replace O-rings
Position R: No power transmission in reverse
a) Signal wire to solenoid 3 grounded
b) Valve piston for reverse gear lock not in parked position
a) Repair/replace wire harness, refer to 24 35 501
Hard engaging jolt in position R
a) Damper of brake D malfunctions
b) Modulation pressure too high
c) Wire to pressure regulator faulty
d) Pressure regulator faulty
a) Replace valve body, refer to 24 30 006
b) Replace pressure regulator, refer to 24 34 861
c) Repair/replace wire harness, refer to 24 35 501
d) Replace pressure regulator, refer to 24 34 861
Position D:No power transmission forwards
a) Damper A blocked
b) Signal wire to solenoid 5 grounded
b) Repair/replace wire harness, refer to 24 35 501
Hard engaging jolt in position D
a) Damper of clutch A malfunctions
b) Wire to pressure regulator faulty
c) Pressure regulator faulty
d) Modulation valve malfunctions
c) Replace pressure regulator, refer to 24 34 861
d) Replace valve body, refer to 24 30 006
Hard shift jolts in general
a) Modulation valve malfunctions
b) Repair/replace wire harness, refer to 24 34 501
Position D:No shift 1-2
a) Wire to output speed sensor faulty
b) Output speed sensor faulty
c) Signal wire to solenoid 1 grounded
d) Shift valve 1 seized in parked position
e) Damper C2 or clutch valve C1 seized
f) Shift valve 3 seized in parked position
b) Replace speed sensor, refer to 24 34 871
e) Replace valve body, refer to 24 30 006
f) Replace valve body, refer to 24 30 006
No shift 2-1
a) Signal or positive wire to solenoid 1 faulty
b) Solenoid 1 faulty
c) Shift valve seized in pushed position
b) Replace solenoid 1, refer to 24 34 853
c) Replace valve body, refer to 24 30 006
No shift 2-3
a) Signal wire to solenoid 2 faulty
b) Solenoid 2 faulty
c) Shift valve 2 seized in pushed position
d) Pulling valve 2-3 seized in parked position
b) Replace solenoid 2, refer to 24 34 853
No shift 3-2
a) Signal or positive wire to solenoid 2 faulty
b) Shift valve seized in parked position
c) Pulling valve 2-3 seized in pushed position
Position D:No shift 3-4
b) Solenoid 3 faulty
d) Damper E seized
b) Replace solenoid 3, refer to 24 34 853
No shift 4-3
a) Signal or positive lead to SV 1 defective
b) Shift valve 4 seized in parked position
c) Damper C2 blocked
No shift 5-4
a) Signal wire to solenoid 1 grounded
c) Shift valve 4 seized in pushed position
Car moves off in 2nd gear engaged
a) Signal or positive wire to solenoid 1 faulty, in this case no 5th gear
b) Shift valve 1 seized in parked position
Car moves off in 3rd gear engaged
a) Signal or positive wire to solenoids 1 and 2 faulty
b) Shift valves 1 and 2 seized in parked position
Car moves off in 4th gear engaged
a) General positive wire faulty (transmission without current)
b) Shift valves 1, 2 and 3 seized in parked position
Shift transitions in zero load positions, full load shifts too hard
a) Modulation valve function not O.K.
d) Damper malfunctions
Shift transitions of full load and kick down shifts too long
a) Pressure reducing valve 1 or 2 not O.K.
b) Modulation valve function not O.K.
Engine dies from shift 2-3/3-2 (overlapped control)
a) Signal or positive lead to SV 4 defective
b) Solenoid 4 faulty
c) Pull/push valve 1 moves too hard
d) Aperture for damper G clogged
e) Damper F moves too hard
f) Pull valve 2-3/3-2 moves too hard
b) Replace solenoid 4, refer to 24 34 853
Engine dies from shift 4-5/5-4 (overlapped control)
a) Signal or positive lead to SV 5 defective
b) Solenoid 5 faulty
c) Pull/push valve 2 moves too hard
d) Damper C2 malfunctions
e) Pull valve 4-5/5-4 moves too hard
f) Damper A moves too hard
b) Replace solenoid 5, refer to 24 34 853
Converter lockup clutch - Shift transitions too hard
Converter clutch function impaired
a) Signal or positive wire to solenoid 6 faulty
b) Solenoid 6 faulty
b) Replace solenoid 6, refer to 24 34 853
Engine dies when stopping car in drive position (converter lockup clutch always engaged)
a) Signal wire to solenoid 6 grounded
b) Converter lockup clutch valve seized in pushed position
c) Solenoid 6 faulty
c) Replace solenoid 6, refer to 24 34 853
Shift speed and shift quality generally not O.K.
Temperature sensor not O.K.
Replace wiring harness,refer to 24 35 501
Troubleshooting peripherals
Idling speed control (throttle valve electronic engine power control)
Wrong shift points, oscillating shifts
a) Engine idling speed too high or too low
b) Idling speed control valve faulty
b) Replace idle speed control valve, refer to 13 41 500
Kick down switch
No kick down shifts, only partial load/full load shifts
a) Wire harness faulty
b) Kick down switch faulty
c) Kick down switch maladjusted
a) Repair wire harness
b) Replace kick down switch, refer to 35 41 480
c) Check adjustment, refer to 35 41 480
Program switch: No S program or only S program
a) Signal wire to program switch faulty
b) Program switch faulty
b) Replace program switch, refer to 61 31 265
No W program or only W program
b) Replace program switch,refer to 61 31 265
Position switch (selector lever) : No shifts Car remains in shifted gear
a) No positive supply/fuse faulty
b) Signal wire faulty
c) Switch faulty
a) Replace fuse
b) Repair wire harness
c) Replace switch, refer to 25 16 080
Hier 121 Seiten Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.all-trans.by/assets/site/files/zf/5hp18.pdf
5hp18 Getriebe Delta8 Suche... 0 26.02.2010 01:09
Getriebe: Ölbefüllung 5HP18 E32Schrauber BMW 7er, Modell E32 3 29.10.2008 14:03
E38-Teile: Automatikgetriebe 5hp18 AttiE38 Suche... 0 17.12.2007 15:00
5hp18 phil25 BMW 7er, Modell E32 0 26.03.2007 23:35
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:03 Uhr.
