Alt 08.04.2015, 05:37   #8
Berichte mal, was es war.
Hab uebrigens gerade hier Reparatursaetze gefunden fuer Hauptbremszylinder BMW E32, diverse Motorausfuehrungen
was mir nur auffaellt, die geben immer an Lucas 25.4mm bore size, nicht ATE?
Model Type From To Cylinder Type and Bore Size
7 (E32) 730 i,iL Dec-86 Sep-94 Lucas 25.40 mm
7 (E32) 730 i,iL V8 Apr-92 Sep-94 Lucas 25.40 mm
7 (E32) 735 i,iL Sep-86 Sep-92 Lucas 25.40 mm
7 (E32) 740 i,iL V8 Apr-92 Sep-94 Lucas 25.40 mm
7 (E32) 750 i,iL V12 Sep-87 Sep-94 Lucas 25.40 mm
Important Information Please read prior to purchase
It is common practise for vehicle manufacturers to fit not only different makes of Master cylinder to the same range of vehicles, but also differing sizes. In most cases this information will be needed to confirm the suitability of a particular kit.The size is normally stamped into the casting, however this is not always visible without removing.Sizes are normally expressed in the major measurment, ie 23.8mm bore cylinders will be stamped 23
Tagfahrlicht und weiteres codieren timm l. BMW 7er, Modell E65/E66 117 12.01.2020 23:02
E32-Teile: H31 BKV + HBZ + Ventil + Behälter + Pumpe + Schläuche HIGH-LINE Suche... 1 26.05.2014 14:02
EDC und weiteres Kontrollieren? |)aywalker BMW 7er, Modell E32 15 13.01.2007 17:11
Werkstattkosten Achsmanschette und weiteres planetb BMW 7er, Modell E32 0 30.01.2005 17:59
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:38 Uhr.
