Alt 23.05.2009, 23:20   #3
ABS Steuergerät Anschlüsse E32
aus BMWs Elektronikwerkstatthandbuch:
Pin Nr........Richtung..........Funktion.............. .....Position
1...............E.................Battery......... ..............ABS Relais
2...............A.............Switched Ground..........Magnet Valve Front Left
4...............E.................Switch.......... ..............Wheel Sensor
6...............E.............Wheel Sensor Front Left........--------------
7...............E.............Wheel Sesnor Rear Left.........--------------
9...............E.............Ground.............. ...............Wheel Sesnor Rear Left
10.............E..............Ground Distribution..............-----------------
11.............E..............Wheel Sesnor Front Right.....------------------
14.............E..............Pump Relais Input...............-------------------
15.............E..............Battery Power.....................Generator
18.............E..............Switched Ground..................Magnet Valve Rear Left
19.............E..............Switched Ground..................Magnet Valve Rear Right
20.............E..............Ground Distribution..............------------------
21.............E..............Ground.............. .................Wheel Sensor Front Right
24.............E..............Wheel Sensor Rear Right.......------------------
25.............E..............Brake Light Switch................------------------
26.............E..............Ground.............. .................Wheel Sesnor Rear Right
27.............A..............Switched Ground..................Valve Relais
28.............A..............Switched Ground..................Pump relais
29.............A..............Display Ground....................Check Control Display
32.............E..............Display Valve Relais (?).........Valve Relais
34.............E..............Ground Distribution................-----------------
35.............A..............Switched Ground...................Magnet Valve Front Right
Hinweis: E ist Eingang zum Steuergeraet, A ist Ausgang vom Steuergeraet.
Anschluesse, die nicht erwaehnt wurden, sind nicht angeschlossen.
Widerstandswerte:
Radsensoren <1 Ohm
Ventilrelais 70...100 Ohm
Motorrelais 34-58 Ohm
von:
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) www.750i.de - Die BMW 750i Seiten
Alle Zeitangaben in WEZ +1. Es ist jetzt 23:35 Uhr.
