26.04.2009, 12:06
Fahrzeug: e38 740i FL-04/99
Zitat von Erich
Die geben hier an:
Das Öl entspricht folgenden Spezifikationen und Klassifikationen:
VW TL 52146 (G002 000), BMW 81 22 9 407 758,
Opel 1940 766, MB 345.0, Citroen LHM.
LIQUI MOLY - Motorenöle, Additive, Autopflege
Nur finde ich diese BMW Teilnummer nicht im online Ersatzteilkatalog.
Kann da mal jemand nachschaun, was das bei BMW im ETK ist?
Hallo Erich.Ich Fahre nur das Liqui Molli komplet problemlos.
26.04.2009, 13:08
CHF 202 ist nichts fuer unsere E32, hier mal kopiert:
CHF 7.1, CHF11S, and CHF202 are are high performance hydraulic fluids formulated for central hydraulic systems such as power steering, rear axle steering, level control, hydro-pneumatic suspension, and shock absorbers.
Pentosin Hydraulic Fluids are ideal for cold weather climates, and also perform exceptionally well under extreme temperature changes, with an operating temperature range from -40º F to +275º F
CHF 7.1 is a mineral oil based fluid; CHF11S and CHF202 are synthetic oil based fluids. CHF 7.1 fluid is green in color, and CHF11S and CHF202 are dark green in color. Available in a 1 liter bottle (1.06 quarts).
Pentosin hydraulic fluids are suitable for the following applications:
CHF 7.1: Audi/Volkswagen (1984-1989)
BMW (1987-9/1991)
Volvo (1995-1998)
CHF11S: Audi (1990-2006) TL52 146.00
BMW (9/1991 on); all beginning with model E32
Chrysler Crossfire 05127381AA
Dodge Sprinter (all years)
Mercedes-Benz (staggered S-class models from 1996 on)
Mini (2002 on)
Nissan (1994 on)
Porsche (1995 on)
Rolls Royce
Saab 900 coupe (95 on); 900/9000
(97-98); 9-5 (98 on)
Volkswagen (1990-2006) TL52 146.00
Volvo (3/1998 on)
CHF202: Audi (2006 on) TL52 146.01
Porsche Cayenne (2005 on)
Saab (2006 on)
Volkswagen (2006 on) TL52 146.01
Volvo (2002 on)
Important note on fluid compatibility: if vehicle specifications state CHF7.1, CHF11S and CHF202 can be substituted in place of, but not mixed with, CHF7.1. If vehicle specifications state CHF11S (or CHF202), do not substitute with CHF7.1. CHF11S and CHF202 are fully compatible and mixable. Pentosin CHF fluids should not be mixed with ATF fluids. Always check your owner's manual to confirm the correct fluid is being used for the vehicle.
26.04.2009, 22:29
#13
Fahrzeug: S50B32
Ich tippe mal im Lotto und vermute die werden LHM+ angeben, ist mineralisch, mit älteren Spezifikationen mischbar (weil mineralisch...) und entspricht "B71" -> 7.1???
Grüsse
Michael
26.04.2009, 22:43
BastardOperatorFromHell
ich hab das LM jetzt schon fast ein jahr drin - bisher keinerlei probleme mit schläuchen oder der pumpe. alles nach wie vor schön.
kann also bedenkenlos eingesetzt werden.
27.04.2009, 09:17
#15
750i powered by ROTTALER2
Hier die Antwort auf meine Anfrage........................
Sehr geehrter Herr Becker,
es ist in der Tat so, dass nur noch begrenzte Mengen dieses Produktes hergestellt werden können. Diese Mengen sind für BMW-Händler reserviert, so dass Sie das Pentosin CHF 7.1 in jeder BMW-Werkstatt erhalten werden.
mit freundlichen Grüßen / kind regards
Deutsche-Pentosin Werke
Deutsche Pentosin-Werke GmbH
Industriestraße 39-43
D-22880 Wedel
Tel.: +49 4103 9134 0
Fax: +49 4103 9134 71
email: info@pentosin.com
Geschäftsführender Gesellschafter / CEO & Shareholder: Jürgen Niemax
Amtsgericht / Local Court: Pinneberg HRB 1556
USt-Id-Nr / VAT-Id-No: DE 134 796 898
Steuer-Nr / Tax No: 1829601292
Viele Grüsse
Peter
27.04.2009, 10:29
#16
Danke fuer die Anfrage da, Peter.
Das Febi ist billiger als Pentosin, also kein Problem.
Gibt es z B bei Stahlgruber, oder hier
autoteile.cc
und glaub ich auch bei A.T.*
denn das selbe Zeug wird ja auch in Seat, Audi und VW benutzt, und die armen Porsche und RR Besitzer kaufen da auch ein.
nur aufpassen, FEBI hat auch 2, einmal fuer CHF 7.1 =
M(0)6161 und das andere fuer CHF 11S = S(0)6162
Und das ist die Info und Zusammenstellung von den Audi 100 fans dazu
Audi100.Selbst-Doku.de : Main - Grünes Gold
27.04.2009, 12:24
#17
autoteile.cc
Tjaaaaa, das Febi (0)6162 hat mir mein Teilehändler damals als 7.1 Ersatz
verkauft... also nicht!!!! das (0) 6161, was nach Deiner Auflistung das
richtige wäre.......
Viele Grüsse
Peter
27.04.2009, 12:34
#18
Welches verwendest Du, ich war gerade mal auf der Liqui Moly Seite, da gibt
es ja HLP 10 oder HLP 15 oder HLP 22..... alles Hydrauliköle .........
Ich müsste ja dann auf eins ausweichen,welches dem Pentosin 7.1 entspricht.
Viele Grüsse
Peter
27.04.2009, 12:41
#19
M = Mineralisch
S= Synthetisch
daran siehst Du schon was das richtige ist.
27.04.2009, 12:45
#20
Normal ist, wie ich bin!
Nach dem der Teilehöker in meiner Strasse Pentosin nicht im Programm hatte und wegen Ersatz auch nicht 100%ig sicher war habe ich dann beim Freundlichen gekauft und dort weniger als 'nen 10er für einen Liter 7.1 bezahlt.
Laut Peters Ausführungen oben wird das Zeug ja noch produziert und ist bis auf weiteres bei BMW erhältlich.
Tüssi, Andreas
Nomaal is dat nich ...
