			17.08.2007, 08:53
			 über 20 Jahre dabei…
Fahrzeug: E65 730d 2004, E66 760 Li 2003, Porsche Cayenne S 4.8 2007, MB SL 500 2003
		Also checked the sensor on the rear axle? Right rear only. Clean the connection. Maybe a broken wire? Use a new sensor.
Alpina? You don´t really ask this question, huh?
Markus
Avatar: Mein 90er E32 R6 (2001-2009 gefahren)
			17.08.2007, 08:58
		Really,
      I have the ALPINA spoiler and stripes on the car.  Does this automatically mean that it's a real Alpina?  Is there a special clear code for the Bremsbelage in the check control.  I've disconnected the rear and front sensors and the light/warning is still there.
			17.08.2007, 09:05
		Who is the manufacturer of the car in the papers? BMW or Alpina? If it is Alpina, it´s a real Alpina.
The stripes and so are not automatically an indicator for a real alpina. A friend drives a E28 520 in fully Alpina-Style. Check the VIN or phone to Alpina.
			17.08.2007, 09:09
		It´s possible that the Check-Control-Modul has a malfunction. Change it for trying. It´s placed in the fuse-box left side of the car. Only pulling for disconnecting.
			17.08.2007, 09:35
		Danke Markus...I must go to the TUV (American inspection) on the Kaserne next week and don't want them to say anything.  The pads are good but the Check control says pads are bad.  Going to Hockenhiem for the NITRO OLympics Drag racing this weekend.  Will take care of the check control early next week.  Danke fur die information....
			17.08.2007, 09:54
			 Some say...
		Perhaps in the past the pads have been changed, but not the indicator.
Try anew one, it costs about 12 Euro.
			17.08.2007, 09:59
		I've disconnected the indicator (sensor) completely at the wheels.  (left front and right rear) There is no contact from those points.  I thought that maybe the check control has to be reset at the dealer of some other "special trick".
			17.08.2007, 10:03
		Konnt auf auch Deutche schriben.  Kann gut leisen, aber nich gut schriben.  Bin U.S. Soldat.
			17.08.2007, 10:14
			 Some say...
		OK, in german.....
Wenn kein Kontakt verbunden ist, dann wird in jedem Falle eine Meldung in der Check Control angezeigt.
Zu beachten ist, dass es immer eine Weile dauert, bis die Meldung verschwindet.
So muss man nach dem Wechsel der Beläge erst ein paar Kilometer fahren, bis das Modul den Wechsel erkennt, dann erlischt die Meldung von alleine.
Das alles im Stand auszuprobieren bringt nicht viel.
In jedem Falle müssen heile Sensoren vorhanden und auch richtig angeschlossen sein, damit die Check Control keinen Fehler anzeigt.
