04.12.2012, 14:13
Fahrzeug: E32-750iL (09.91).
Price for front seats E32 Long. Und : Furnieren von Klapptischen
Hallo!
I have theese seats:
After renovation:
They are from the E32 HighLine. Electrical.
Can you tell me the price of these?
Vielen dank!!!
05.12.2012, 16:09
Möchtegern-Experte
Fahrzeug: e32 730i V8 M60-Handschalter Bj. 8-92 Zenit-JZ2005-LPG
It's hard to say what the price for these seats could be. In Germany you'd find certainly someone who'd pay up to 300-400 € for them. But if you should live in the UK, for example, they are nearly worthless. I don't know why, but I've already seen very low prices for such seats on ebay.co.uk. In the UK you can buy whole e32 interieurs for 1 L sometimes. I already thought about that, but the main problem would be the shipping, which would be around 200-300 €. Thus, I'd offer you hereby 1€
Hubraum ist durch nichts zu ersetzen... ...außer durch ein Schaltgetriebe  => Lang lebe mein M60-Handschalter!
Suche: Doppelglastüren Sterlingsilber / Nappa-Volleder-Teile schwarz (Fahrer-Türgriff mit intakten Nähten, Sitzpappen m./o. Tische, Armaturenbrett) / NFL-Nußbaum-Vesperbrett f. Handschaltung & Volleder / Leselampen hinten -9/88 (1 Stecker)
Tausche weg: Leselampen hi. (2 Stecker) / Doppelglastüren rot&schwarz
Biete bei hood Lübeck/Kiel Bln.
05.12.2012, 16:29
IMHO they are nearly unmerchantable. The most characteristic feature, the picnic tables, are worn out, split and slightly stained, as you can see below. No one would put them in his car in that condition. They'll have to be prepared by a carpenter or varnisher.
05.12.2012, 17:03
Engine Bay - Diving Co.
Highliner is allright!
I would not put them in my Highline because of the picnictables condition.
The only worthy thing at it are the picnictables, refurbished and in good condition they are to sell, for i guess about 500€/pair ...
The seats just increase the porto & package rates!
Cheers
Andreas
Andreas
InEfficientDynamics
Leider Geil
2 "Es ist nie nichts!"
05.12.2012, 17:11
Möchtegern-Experte
And 500 €/pair would probably exactly be the price to pay for a professional refurbishment
05.12.2012, 17:23
Yes, exactly! Thats it and what you pay for...
The tables in that condition are nearly worthless i guess. They are even worser than mine were... As i can see on those pictures.
Kind reguards
Andreas
05.12.2012, 18:50
Lernfähiges Mitglied
Fahrzeug: BMW R1200RT
It depends where they are located. In a country with a good market, maybe 100 Euro per Seat as they are without armrests and another 100 for each table, considering the bad condition, not so interesting for owners of a Highline, but definately interesting for those with a normal E32.
05.12.2012, 23:25
Serifus versteht ja auch ein bischen Deutsch, er kann es nur nicht schreiben, deshalb schreibt er in Englisch. Nun lasst uns mal auf Deutsch weiter machen.
Zu den Tischchen:
Ich hab auch noch welche in Reserve, die -wie die meisten- geplatzt sind.
Hab die mal untersucht, das Furnier ist hauchduenn aufegtragen. Ist es wirklich so teuer (500 EURO), die wieder neu mit Furnier zu machen?
Kollege hat noch einen weiteren Tisch da und mal etwas abgezogen vom Furnier. Darunter ist anscheinend Alu. Das Furnier ist da nur draufgeklebt.
Wenn man das Furnier neu macht (klebt) und dann dicke Klarlackschichten drueber lackiert in mehreren Stufen, dann muessten die eigentlich wie neu aussehen.
Schliesslich sind da einige Teile dabei, die gibt es ueberhaupt nicht mehr bei BMW.
Selbst der Klapptisch ist nicht mehr lieferbar, und auch die Kleinteile
Ruckwand Sitz/Klapptisch BMW 7' E32, 750iL (M70) ? BMW Teilekatalog
Hat schon jemand das Furnier neu gemacht bzw neu machen lassen?
500 EURO fuer das bischen Furnier erscheinen mir hoch, kenn mich aber damit nicht aus.
05.12.2012, 23:42
'The Perforator'
Fahrzeug: Ka eF Zett
Das Problem beim Funieren sind die Rundungen. Wenn du eine Ebene Fläche funierst, oder eine mit einer 1-Dimensionalen rundung (also ein Normales Rohr, oder Rohrbogen) dann geht das mit normalen Pattex Kontaktkleber, genauso haltbar wie Original.
Das Problem hier ist die Form der Fläche, d.h. du müsstest das funiert erstmal in Form bringen bevor du es aufträgst. dazu brauchst du eine Presse die auf etwa 120°C heizen kann und eine Form. Das Funier selbst ist günstig. Presse habe ich hier bei einem Kunden, die Hat 2mx1m und kann ganze Türen funieren.
Die Form müsste aus Alu sein, und man bräuchte Positiv und negativ (also abdruck vom Tisch, und Tisch selbst) aus Alu/stahl/Messing/whatevermetal. Wenn man das einmal Hat kann man Funker pressen wie Blöde.
Alternative wäre die tische komplett aus Holz nachzubauen, was warscheinlich sogar einfacher wäre, CNC-Fräße vorausgesetzt. dort zahlt man zwar etwas mehr fürs Holz, aber hat dann natürlich komplette Freiheit in der Design Wahl.
Das mit dem Lackieren wird dann nochmal schwer, ich würde es machen lassen, denn sonst Springt es wieder. Man braucht für "hochglanzHolzlack" schon 2 spezielle vorbehandlungen. und wir reden hier von einem Bauteil in einem KFZ, welches zwischen -30°C und +90°C, UV-Bombadiertung und Relativer Luftfeuchte von 2% bis 95% aushalten muss. keine Optimale Bedienung für Holz. Das material lebt und arbeitet halt leider immernoch, der Lack nicht :/
06.12.2012, 06:43
Sind die Risse denn ins Furnier ? Ich bin kein Möbelmacher aber ich weiss dass vieles an Reparatur möglich ist, vielleicht kann man auch abschleifen und neulackieren.
