Alt 13.05.2009, 00:06   #31
Wing
Fahrzeug: E0 30 Cabrio 318,Golf2,MantaB 3.0ltr. Yamaha 1200
Hi!
Meiner läuft noch!
Bei mir war es eine defekte neue Verteilerkappe mit Läufer
Mfg
Wing
Wing ist offline   Antwort Mit Zitat antworten
Alt 13.05.2009, 05:51   #32
hier mal die Bestaetigung wie wichtig die Zylinder 6 und 12sind wegen der 2 Donuts, aus RF E31 forum:
Subject: I guess its my turn...Running on 6 cyllinders
Started it up. A little condensation smoke then awesome...
Left town for 6 days...Come home and start her right up..No problem. Drive her around town and get a coffee. Start her up...Only starts on 6! How do I know? Extremely sluggish and sputtering feeling. No major power. Drive it home (The long way) to look at it. No lights light up...No check engines or anything. One week later I ordered another DK motor from Wuffer because I thought that was it. Changed out both and still chugging and running on 6. No check engine lights either. Read through the archives... Mine is a 93 850ci with 126k , I changed plugs at 100k
fuel filters at 105k, air filter 1k ago, O2 sensors about 10k ago, new Dk motors, IM gaskets about 5k ago.
reading through archives now...looking to find someone with a similiar problem. I am wondering about Spark plugs or wires....But so soon?
Antwort von Mark in SBA , den ich sehr hoch einschaetze mit seinem Fachwissen:
Yes, it would. If plug lead 6 or 12 (the ones with the inductive pickup donuts on them) are disconnected or short, a protection circuit embedded within the Motronic will severely clip the duty cycle of the injectors for that side to protect the catalysts from being drenched in raw, unburned fuel.
I may have posted this before:
Catalytic converter protection function
Ignition circuit monitoring
The ignition circuit is monitored by the cylinder detaction sender (pin 16) on ignition line 6 (or 12). If it detects no ignition signal on ignition line 6 (or 12) , the fuel supply to to the relevant cylinder bank is cut out by shortening the injection signal. The sender monitors the entire primary side of ignition, and cylinder 6 or 12 on the secondary side.
The inductive sensor is outlined in red above.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.fibersonde.com/e31/images...catprotect.jpg
Das ist jetzt von der MOTRONIK 1.7, ich denke mal - bin mir aber noch nicht sicher - das es das selbe bei der 1.2 ist.
Kann man aber mal selber pruefen, einfach mal einen der Stecker abziehen von den Donuts, und dann starten des Motors.
Motorraum: Mein V12 läuft nur mehr auf 6 Zylindern rene25 BMW 7er, Modell E32 51 16.10.2019 07:55
Motorraum: 740 Läuft nur auf einer Bank maxicelina BMW 7er, Modell E32 16 14.11.2008 17:33
Langsam werde ich sauer! Er läuft nur noch auf einer Bank! Wing BMW 7er, Modell E32 34 01.07.2008 17:22
Motorraum: Nur eine Zyl-Bank läuft noch! Vince-V12 BMW 7er, Modell E32 9 21.03.2005 17:41
V12 läuft nur auf einer Bank II tntx BMW 7er, Modell E32 21 05.09.2003 20:28
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:14 Uhr.
