Alt 02.01.2013, 17:05   #1
Beumers
Fahrzeug: E32-735i dec 1986
Standard Which fluid do I need for my servo?
Hi all.
My car: 735i 1986 dec.
My problem. The manual says I have to use pentosin CHF 7.1 for the steering/selfleveling control. All pentosin fluids are green but my container has a red fluid in it like ATF.
Everything works well, and maybe it's fine but I can't find out what sort of fluid is in the container. If I want to change the fluid at the periodical service I don't know what fluid to use.
Anybody has some info about these fluids.
No need to reply in English.
Gruss Henk Beumers.
Beumers ist offline   Antwort Mit Zitat antworten
Alt 02.01.2013, 19:41   #2
Johan735
Benutzerbild von Johan735
Fahrzeug: E32-750i | E39-525i | F10-523i
I see you have an 86 e32. These always came with a hydraulic brake booster. And were filled with ATF fluid. Only if the car had LAD suspenstion (which I've never seen on an 86 but to everythig there is first) has pentosin CHF 7.1.
Groeten,
Johan
Johan735 ist offline   Antwort Mit Zitat antworten
Alt 02.01.2013, 22:52   #3
Beumers
Thanks Johan for your reply.
It would explain a lot, but I'm a bit confused now. What's the difference between LAD and self leveling supension? I read somewhere that you can tell LAD when the reservoir is a metal one with a half rond wire mesh. My car has this metal reservoir but it has no label Pentosin on it, nor does it have a ATF label. The user manual is from 1992. So it's confusing. I have to check under the car but I'm almost sure there are a lot of metal pipes going to the back of the car and, as I thought, to the struts in the back. But I have to look again to be sure.
Henk.
Alt 02.01.2013, 23:39   #4
LAD and self levelling suspension are same, only different name.
What is your fluid colour? Pentosin CHF 7.1 is light green, ATF is usually red.
Alt 03.01.2013, 00:03   #5
Beumers
Hi Erich.
The color of the fluid is red like ATF. I was reading about the LAD and I'm almost sure I have this system in my car. Also Bentley says the fluid must be Pentosin so it should be green. Tomorrow I will have a look under my car and locate the several parts of the suspension. I know there are metal pipes running to the back and levers are attached to the stabilisor. Also the struts have these containers at the side so I'm almost convinced that there is LAD on the car. I can't remember seeing the bomb there though.
I drive the car for more then a year now and nothing is noticeable wrong with the suspention. Can it hurt the system on ATF. Is there an other fluid with this redish color like ATF?
More tomorrow. thanks.
Henk.
Alt 03.01.2013, 00:16   #6
12/86 could still be with this self levelling pump in the trunk as shown here
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Rear axle ? illustrations BMW 7' E32, 735i (M30) ? BMW parts catalog
I have never seen it life.
Shell fluid 41 BENNUS Suche... 4 07.12.2009 18:33
AeroShell Fluid 41 - Suche oder Sammelbestellung? Bastl Suche... 6 18.11.2009 10:24
Karosserie: Korrosionsschutzbehandlung mit Fluid-Film und Perma-Film HGW E38: Tipps & Tricks 0 26.03.2009 23:34
Alle Zeitangaben in WEZ +1. Es ist jetzt 14:17 Uhr.
