Alt 10.05.2015, 23:14   #1
Beumers
Fahrzeug: E32-735i dec 1986
Standard Oil cooler
Hi all.
I have a little trouble with my oil cooler.
So, if I disconnect the oil cooler hoses from my oil filterhousing and I close the holes with a plate. Can I run my car (735 from 1986 ) like this for a while. I mean, will the oilpump still be able to pump the oil trough the whole system.
I know there were models without an oilcooler but maybe they also had a different oilfilterhousing.
No need to reply in English.
Thanks Henk.
Beumers ist offline   Antwort Mit Zitat antworten
Alt 10.05.2015, 23:21   #2
boxerheinz
Benutzerbild von boxerheinz
Fahrzeug: e38 740i FL-04/99
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://de.bmwfans.info/parts-catalog/11421713345/
mit Ölkühler
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://de.bmwfans.info/parts-catalog/11421720690/
not Ölkühler
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://de.bmwfans.info/parts-catalog...em_oil_filter/
Geändert von boxerheinz (10.05.2015 um 23:28 Uhr).
Alt 11.05.2015, 10:51   #3
Beumers
hi Boxerheinz.
Thanks, but it's not about the oilfilterhousing. I want to disconnect the oilhoses from the oilcooler and I like to know if the oil circulation through the engine will be blokked if I do so.
Henk.
Alt 11.05.2015, 11:21   #4
boxerheinz
As it is now with you you need a circuit to the motor.
It is only then when the housing is also changed by the oil filter.
Alt 11.05.2015, 12:14   #5
Beumers
Hi boxerheinz.
write it in German.
Thanks Henk.
Alt 11.05.2015, 12:20   #6
boxerheinz
Beim Ölfiltergehäuse mit Ölkühleranschlss ist es ervorderlich das der Kreislauf bestehen bleibt.
Alt 11.05.2015, 12:46   #7
Beumers
Danke.
I wil try and fix it that way.
Henk.
Alt 11.05.2015, 18:34   #8
Beumers
Oké. I fixed it for now. Works well. Only problem is the oilpump belt. It slips through spilled oil so I don't have powerstering and breaks. Will fix that tomorrow.
Henk.
Alt 11.05.2015, 19:23   #9
boxerheinz
Ok
Motorraum: Oil pressure Beumers BMW 7er, Modell E32 12 29.03.2015 16:41
Cooler HARTGE :-) Raffael@735i eBay, mobile und Co 13 18.08.2008 16:21
Lenkung: OIL für lenkunterstützung Heffernan187 BMW 7er, Modell E32 50 08.02.2008 20:02
Motorraum: Oil Filter Rosemary BMW 7er, Modell E32 6 06.05.2006 22:45
Elektrik: Oil Temparatur Riverghost BMW 7er, Modell E32 3 17.06.2004 12:58
Alle Zeitangaben in WEZ +2. Es ist jetzt 12:45 Uhr.
