Alt 22.01.2009, 19:37   #1
Erlingur
Fahrzeug: E32 750 '91
Frage 750 end bearing part number
Hello E32 friends,
I need to change the end bearing in my ZF on my 750 '91.
Can you tell me the factory number of the bearing (specific size), I assume that the bearing is much cheaper if I buy it from my local bearing dealer SKF or FAG/INA than from the BMW dealer.
According to real oem it is needle bearing 35x42x12 I assume that it should be easy go buy that one, but do you think that I need the inner ring also, and is possible to get the inner ring off with the trans under the car.
I would also need the size and number for the rear seal.
I just bought two valve cover gaskets that did cost more than full tank (100L) of 98 okt gas on my car
Best regards from Iceland
Geändert von Erlingur (22.01.2009 um 20:09 Uhr).
Erlingur ist offline   Antwort Mit Zitat antworten
Alt 23.01.2009, 01:49   #2
you will only know the part number of the original maker when the bearing is out and you see the maker and the maker part number.
As usual, the transmission makers do not use the same number in their parts list, to confuse people like you who want to buy is cheaper
maybe this helps
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.jpat.co.uk/jpat_pdfs/ZF%2...20%204HP24.pdf
check their site
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Europeantransmissions*and...
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.zf.com/na/content/media/i...E39D80CAD0DA=1
buy a repair manual
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.zf.com/na/content/media/i...Literature.pdf
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) ZF4HP24, zf 4HP24 :: Korobka.com :: Catalog of Parts for Automatic Transmissions
or buy from Zcech Republic maybe cheaper
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) The list of the automatic transmission types - KAPS Automatické pøevodovky
Next time we do one, I can check, but no schedule to repair one now, too cold.
Alt 23.01.2009, 08:13   #3
Erlingur
Thank you for this.
I'll look through this information and see what I find.
Karosserie: Paar Foto´s Part II Da Grunzl BMW 7er, Modell E38 93 27.02.2011 16:47
VIN (Vehicle Identification Number) Dirk_122 BMW 7er, Modell E38 13 16.02.2006 11:44
Abgasanlage: I am looking for tank part. jelas BMW 7er, Modell E38 0 10.11.2005 19:24
Teilnummer cross reference number, Klasse Erich BMW 7er, Modell E32 2 17.06.2005 05:36
trying to find part number for water hose Petri BMW 7er, Modell E23 1 20.05.2005 08:18
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:13 Uhr.
