BMW 7er, Modell E23
Alt 17.01.2017, 21:51   #1
lipaa1
Benutzerbild von lipaa1
Fahrzeug: BMW 7er E23 Mai 1982\Passat B5.5 V6 4 motion
Standard change the gearbox
Hello,dear fans of BMW
Many years had passed,or rather 5,as I began to revive my E23.
It is almost completed,it remains only to change the gearbox(Getrag 265),clutch kit,driveshaft, and rear beam bushings. Yes,still put the LSD in the rear gear
Tomorrow begins the dismantling of the old parts,I will try to do a photo and the story step by step,suddenly someone come in handy!
Thank you for your attention!
Dateityp: jpg WP_20170117_16_10_40_Pro.jpg (87,8 KB, 25x aufgerufen)
Dateityp: jpg media-share-0-02-05-5521983505cc7b3c4992d25a2f5952b1537700e61199d15e679451d793931743-8952f3df-8e.jpg (96,2 KB, 24x aufgerufen)
Dateityp: jpg WP_20170112_09_08_12_Pro.jpg (101,6 KB, 24x aufgerufen)
Geändert von lipaa1 (17.01.2017 um 21:56 Uhr).
lipaa1 ist offline   Antwort Mit Zitat antworten
Alt 17.01.2017, 22:03   #2
oetti
Allround Dilettant
Benutzerbild von oetti
Hy, well that was a long way for you, but now there seems to be an end in sight. And the E23 comes back into the street, how long has he been standing?
Alt 18.01.2017, 17:28   #3
Percy 2016
Fahrzeug: E23 732ia (06.1980)
Hi lipaa1,
I´m quite astonished to find an E23 friend in St.Petersburg
Last year I rebuilt an E23 as well, and can imagine, that you in contrast to me, have propably problems , to get spare parts.
But it seems that you have everything together. If you still need something special, send a message and we will try to help.
Best wishes Bernd from Germany
Percy 2016 ist offline   Antwort Mit Zitat antworten
Alt 18.01.2017, 21:21   #4
lipaa1
английский
Before me about 6 years old I drove during the tenure of all 2000-3000 km
Alt 18.01.2017, 21:28   #5
lipaa1
Zitat von Percy 2016 Beitrag anzeigen
Hi lipaa1,
Many thanks
In Russia, you can buy new parts. You can buy a "contract" details. You can buy e23 entirely on the details
That's how we live. Sometimes I buy E-bay. But hardly anyone in Germany makes the delivery in Russia, one can understand
Alt 18.01.2017, 21:47   #6
lipaa1
So, I start the repair
Good evening!
Started today at nine o'clock, I finished about 14, with a few distractions in the immediate work
All operations were carried out at the pit with a minimum set of tools and single-handedly. ASE helped me board.
First of all, the muffler removed. Fortunately put it recently, all was calm.
Unscrew the six nuts 13 in a single place-pants Glushak connection. Bolts held the key to 12. Or head who has what.
Then he unscrewed the bottom of the back yoke. The board planted at the rear bank and took the gum with medium banks. All substitute its own ridge and pulls off this piece of iron with a reception pipe. On the floor it.
Now cardan. A pair of keys 19 for the coupling bolts. On average 13 to support. Again, the board helps cardan falls on it. It remains to unscrew 4 screws that secure the cardan gear to the shank. If not mistaken, there are 17 ring spanner. Remove the universal joint, bear comparison with those that have left and wonder.
The front part odinakovye.Zadnie slightly different, which in theory should be not. Do not care, no options, it is still going to put my other universal joint for some tired.
Next come the half-line. Make sure you first need to clean the bolts from nabivsheysya dirt, or hexagon can easily rip the faces provernuvshis.
The last thing for today was the removal of the gearbox. There is also more or less just, the key cap 19 for the top two bolts. The head 19 to lower. And bolt to the support.
Previously not forget to substitute any board or support under the gearbox, or a little fall. All photographed.
The following is a comparison of the regular gear with reduktoromLSD. They used ... be, different. Differences in the rear of the housing and the lid respectively.
To be continued tomorrow, take off the rocker, the box and the clutch
All the while!
P.S.I apologize for my "English", I use a translator online
If suddenly you are interested, I cite a reference to the board of my car magazine on the site drive2.ru
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.drive2.ru/r/bmw/288230376151911691/
Thank you all for your interest and your time
Dateityp: jpg WP_20170118_10_59_18_Pro.jpg (99,5 KB, 13x aufgerufen)
Dateityp: jpg WP_20170118_09_44_08_Pro.jpg (101,5 KB, 13x aufgerufen)
Dateityp: jpg WP_20170118_14_48_44_Pro.jpg (87,5 KB, 13x aufgerufen)
Dateityp: jpg WP_20170118_15_12_40_Pro.jpg (95,3 KB, 15x aufgerufen)
Dateityp: jpg WP_20170118_15_13_15_Pro.jpg (98,4 KB, 15x aufgerufen)
Dateityp: jpg WP_20170118_15_32_18_Pro.jpg (101,9 KB, 15x aufgerufen)
Alt 18.01.2017, 22:23   #7
oetti
Allround Dilettant
Well then welcome to the circle of reawakeners, Sleeping Beauty Drivers. Bernds E23 (Perci) stood for 16 years in a garage and my E23 B9 Alpina stood 14 years forgotten in a Berlin underground car park.
Alt 19.01.2017, 05:49   #8
lipaa1
Here a little differently, pictured in the profile can be seen in what condition I got a car!
I do not think you bought a car in this state 😁
Alt 19.01.2017, 07:32   #9
In case you need the workshop manual, tightening torques, nominal values, here is a link Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) https://www.bmwtechinfo.com/repair/main/
wiring diagrams are here, note: US version
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) E23 (1982 to 1986 7 Series) Wiring Diagrams
Alt 19.01.2017, 21:55   #10
lipaa1
Vielen Dank!
Solche Links, habe ich nicht gesehen!
Gearbox jassenko BMW 7er, Modell E65/E66 0 12.09.2014 22:10
*Picture*, This gearbox is a bit rusty, do you think it will work fine? 7ertzen BMW 7er, Modell E32 3 04.02.2014 21:23
Getriebe: Oil seal gearbox replacement Beumers BMW 7er, Modell E32 7 05.07.2013 23:35
Getriebe: BMW 745 li ZF gearbox problem-shematic diagram Dalibor-zg BMW 7er, Modell E65/E66 3 11.08.2012 14:35
how to change language EmilC BMW 7er, Modell E38 11 24.06.2005 16:07
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:10 Uhr.
