		|  06.10.2011, 22:04 | #1 |
	| Eyes Wide Shut
Fahrzeug: E38 740iA PD 09/95
				 Techn. Begriffserklärungen rund um alle 7er - Abkürzungen aufgeschlüsselt
 @Knuffel
Du meinst so ne kurze, übersichtliche, Auflistung?
Sind zwei Teile.
Teil 1: Englisch (teilweise mit deutschen Begriffen ergänzt)(Wie die Lottozahlen in den Nachrichten: Ohne Peng, ähh... Gewähr!  )
Teil 2: Deutsch (Quelle E*T*K*)
Teil 1 Glossary of BMW Terms and Abbreviations ---------------------------------------
 A - processed vehicle speed signal
 A - "out" (Aus)
 AB - Airbag
 ABL - Brake system warning Lamp (2 color)
 ABS - Anti-lock Braking System----Antiblockiersystem
 AC - Air Conditioning (from ETK)
 ACC - Active Cruise Control
 ACS - Active Comfort Seats
 ADB(X) - Automatic Differential Braking
 ADS - engine intake air control
 ADV - windshield wiper pressure control----Anpressdruckverstellung
 AEGS - Automatic Electronic Gearbox Control (also EGS)
 AFM - Air Flow Meter----Luftmengenmesser
 AGD - suction silencer (from ETK)----Ansauggeraeuschdaempfer
 AGR - emission reduction
 AGS - Adaptive transmission control----adaptive Getriebesteuerung
 AG - Automatic Gearbox (transmission)----automatisches Getriebe
 AHK - Active rear-axle Kinematics
 AHK - trailer hitch (from ETK)----Anhaengerkupplung
 AHM - trailer Module (not for US models)
 AHPS - Advanced HPS
 AIC - Automatic Interval Control (rain sensor)
 AKF - activated carbon canister (from ETK)
 AKS - Active head restraint
 AKS - pressure regulating device (from ETK)
 ALC - Automatic Light Control
 ALR - Automatic Lamp Range Adjustment
 AMM - Air Mass Meter----Luftmassenmesser
 AMP - radio system AMPlifier
 ARI - car radio information system (from ETK)
 ARS - Active Roll Stabilization
 ASC - All Season traction
 ASC-EZA - ASC w/ engine timing and injection intervention
 ASC+T - ASC+ Traction control
 ASK - Audio System controller (Kontroller)
 ASR - self starter block relay (from ETK)
 AST - Automatic Slip control (marketing term)
 AT - remanufactured part (from ETK)
 AT - Antenna (from ETK)
 ATF - Automatic Transmission Fluid (from ETK)
 ATL - exhaust gas turbo charger (from ETK)----Abgasturbolader
 AUC - Automatic air recirculation
 AUT - AUTomatic transmission (from ETK)
 AVT - Antenna amplifier Tuner
 AZD - tightening torque specifications (in TIS)
 A/D – Analog/Digital
 B - Benzene (gasoline)----Benzin
 BAT - BATtery (from ETK)
 BC - Board Computer
 BC1 - Body Controller 1
 BL - Brake Light (from ETK)----Bremslicht
 BLS - Brake Light Switch----Bremslichtschalter
 Bluetooth - A wireless interconnection technology that automatically recognizes and communicates with components (such as cell phones, headsets and computing devices) when brought into close proximity (generally 30 feet or less).
 BMBT - Board Monitor
 BS - Block diagram
 BST - Battery Safety Terminal
 BVA - Brake pad wear indicator (from ETK)----Bremsbelagverschleissanzeiger
 BZM - center console control center
 BZMF - center console control center, rear
 CAN – Controller Area Network (Multiple ECU Controller)
 CAN-Bus - Controller Area Network (bus)
 CANH-Bus - CAN bus, High
 CANL-Bus - CAN bus, Low
 CANP - fuel tank ventilation valve
 CAS - Car Access System
 CBC - Corner Braking Control
 CBS - Condition Based Service
 CCM - Check Control Module
 CD - Control Display
 CDC - Compact Disk Changer
 CDS - CD player (from ETK)
 CEL - CELsius (from ETK)
 CIM - Chassis Integration Module
 CO - Carbon monOxide (from ETK)
 COMBI – Electronic Instrument Cluster
 CON - CONtroller
 CU - Copper (from ETK)----Kupfer
 CVM - Convertible top Module
 CVT - Constantly Variable Transmission
 CW - drag coefficient (from ETK)----Luftwiderstandsbeiwert
 CWP - Cold Weather Package
 D1 - Xenon light/ gas discharge (from ETK)
 D-Bus - Diagnosis bus (same as TXD)
 DBC - Dynamic Brake Control
 DBS - Dynamic Braking System
 DCS - Dealer Communication System
 DE – Diagnostic Unit----Diagnoseeinheit
 DD - Dynamic motor Drive
 DDE - Digital Diesel Electronics
 DIN - German industrial standards
 DIS - Diagnosis and Information System
 DISA - Differential air intake control
 DIVA - continuously variable length intake runners
 DK - throttle housing/valve----Drosselklappe
 DKB - throttle w/ brake intervention
 DKE – Throttle Increase
 DKI - throttle position
 DKR - throttle reduction
 DKT - throttle position signal
 DKV - preset throttle position value
 DME - Digital Motor Electronics
 DM-TL - Diagnostic Module Tank Leakage
 DOHC - Double Over Head Camshafts (from ETK)----doppelte obenliegende Nockenwelle
 DS - gasket set (from ETK)----Dichtungssatz
 DSC - Dynamic Stability Control
 DSP - Digital Sound Processing
 DTC - Diagnostic Trouble Code (SAE)
 DTC - Dynamic Traction Control
 DWA - theft deterrent system----Diebstahlwarnanlage
 DWS - tire pressure Warning System----Druckwarnsystem
 DZM - revolution counter (from ETK)----Drehzahlmesser
 E - "in" (Ein)
 EBA - EinBau Anleitung (translated Installation Instructions). This is a CD-ROM with installation instructions for various options and upgrades.
 EBV - Electronic Brake force proportioning----elektronisches Bremsventil
 ECE - European market version (from ETK)
 ECM - Engine Control Module (SAE term)
 ECU - Electronic Control Unit
 EDC - Electronic Damper Control (from ETK)
 EDR - Electronic throttle control----elektronische Drehzahlregelung
 E-KAT - Electrically heated catalytic converter----beheizter KAT
 EZA - see ASC-EZA
 ECO - Controller for I-Drive system
 EDC - Electronic Dampening Control----elektronische Daempferkontrolle
 EDC-K - Electronic Dampening Control - Continuous
 EDK - Electronic throttle valve----elektronische Drosselklappe
 EDS - pressure regulator----Druckspeicher
 EFH - Electric window lifter (from ETK)----elektrische Fensterheber
 EGS - Electronic transmission control----elektronische Getriebesteuerung
 EH - Electronic-Hydraulic
 EHC - Electronic Height Control
 EKM - Electronic body Module----elektronisches Karosserie Modul
 EKP - Electric fuel Pump----elektrische Kraftstoffpumpe
 ELV - Electronic steering lock----elektronische Lenkradverriegelung
 EM - Electro-Mechanical----elektro-mechanisch
 EMF - Electro-Mechanical parking brake----elektro-mechanische Fussbremse
 EML - Electronic Motor Load regulation----Elektronische Motorlastregelung
 EMV - Electro-Magnetic sensitivity (from ETK)---elektromagnetische Vertraeglichkeit
 EO - component location----Einbauort
 EPC - Electronic Parts Catalog (also ETK)
 EPROM - Erasable/ Programmable chip Memory (from ETK)
 ETK - Electronic parts catalog (also EPC)----Ersatzteilkatalog
 ETM - Electrical Troubleshooting Manual
 ESS - Electronic anti-theft device----Elektronisches Sicherheits System
 EV - injection Valve----Einspritzventil
 EWS - Electronic drive-away protection----Elektronische Wegfahrsperre
 FB - Function description----Funktionsbeschreibung
 FBC - Fading Brake Control
 FBD - remote control services----Fernbedienung
 FBZV - radio frequency locking system
 FGR – Vehicle Speed Control (Cruise Control)----Fahrzeuggesxchwindi
 FH - window lifter----Fensterheber
 FHK - rear Heater/ air conditioner
 FLC - automatic Light Control
 FRU - Flat Rate Unit
 FS – Crash Sensor
 FZV - central lock receiver
 GAL - speed dependent sound volume----geschwindigkeitsabhaengige Lautstaerkeregelung
 GM - General Module----Grundmodul
 GMR - yaw moment control----Giermomentregelung
 GPS - Global Positioning System
 GRII - cruise control----Geschwindigkeitsregelung II (Tempomat)
 GRS - rotation Rate Sensor
 GS – Belt Tensioner
 GWK - torque converter lock-up control
 H - "rear" (Hinten)
 H2 - Xenon headlights
 HA - rear Axle (from ETK)----Hinterachse
 HC – Hydro Carbon
 HD - Heavy Duty (from ETK)
 HDC - Hill Decent Control
 HFM - Hot Film air mass Meter----Heissfilmluftmengenmesser
 HG - manual Gearbox (transmission)----Handschaltgetriebe
 HKL - Hydraulic trunk lid Lift----hydraulischer Kofferraumdeckellifter
 HLM – Hot Wire Air Mass Meter----Heissdrahtluftmengenmesser
 HPS - Head Protection System
 HR - Heater control (from ETK)----Heizungsregelung
 HVA - Hydraulic Valve Adjuster (from ETK)
 Hz – Hertz (Cycle)
 I-Bus - Information bus
 IB - Interior lighting control signal
 IHKA - automatic Heating and A/C
 IHKAF - IHKA w/ micro filter
 IHKR - regulated Heating and A/C----Integrierte Heizungs-Klimaregler
 IHKRF - IHKR w/ micro filter
 IHKS - standard Heating and A/C----Integrierte Heizungs-Klimasteuerung
 IHPD - Internal High Pressure Deformation
 IHR - Integrated Heater control (from ETK)----integrierte Heizungsregelung
 IKE - Instrument cluster Electronics
 ILH - Interior Lighting, rear----Innenlicht, hinten
 ILV - Interior Lighting, front----Innenlicht, vorne
 IMS - Instant Mobility System (from ETK)
 IR – Infrared
 IRS – Infrared Locking System
 ISC – Idle Speed Control
 ISIS - Intelligent Safety Integration System
 ISN - Individual Serial Number
 ISOFIX - standardized mounts for child restraints
 ITS - head airbag assembly/ Inflatable Tubular Structure
 IVM - Integrated power supply Module----Integriertes Versorgungsmodul
 K-Bus - body bus (Karosserie)
 KAT - catalytic converter----katalysator
 KATON - converter creating (signal)
 KD - Kick-Down
 KDS - Komputer Service Desk (Translated Computer) A CD-ROM that inlcudes the defect codes and flat rate labor units BMW allows for the warranty repair of defects.
 KHI - interface for headphones----Kopfhoererinterface
 KL - terminal designation----Klemme
 KL15 - run bus (ignition switch run position)----Klemme 15
 KL30 - battery bus (hot at all times)----Klemme 30 (Dauerplus)
 KL31 - ground bus (chassis ground)----Klemme 31 (Masse)
 KL50 - start bus (ignition start position)----Klemme 50
 KLR - accessory bus
 KO - compressor "on" signal
 KOMBI - instrument cluster----Kombiinstrument (Tacho-Drehzahlmesser, usw.)
 KOREL - compressor relay signal
 KR – Contact Ring
 KSK - Knock Sensor----Klopfsensor
 KVA - fuel consumption signal/value
 KW - crankshaft----Kurbelwelle
 KW - KiloWatt (from ETK)
 LCM - Lamp Check Module
 LDP - Leak Diagnosis Pump
 LEV - Low Emissions Vehicle
 LEW - Lateral acceleration sensor
 LHD - Left-Hand Drive (from ETK)----Linkslenker
 LKM - Lamp control Module----Lampenkontrollmodul
 LL - closed throttle----Leerlauf
 LM - Light Module----Lichtmodul
 LMM - air flow meter/sensor----Luftmengenmesser/Luftmassenmesser
 LMR - Light alloy wheel----Leichtmetallrad
 LRA - vertical headlight aiming----Leuchtweitenregelung
 LSM - steering column memory----Lenksauelenmemory
 LSZ - Lamp Switching center
 LVA - air supply system (for EHC system)----Luftversorungsaggregat
 LWR - vertical headlight aim control----Leuchtweitenregelung
 LWS-5 - steering angle sensor----Lenkwinkersensor
 M-Bus - IHKA/IHKR stepper motor bus
 MAL - center armrest----Mittelarmlehne
 MBC - Maximum Brake Control
 MDK - Motorized throttle valve/system
 MFL - Multi-Function steering wheel----Multifunktionslenkrad
 MFC - Multi-Function Controller
 MFU - Multi-Function Clock----Multifunktionsuhr
 MID - Multi-Information Display
 MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
 MIR - Multi-Information Radio
 MMC - Multi-Media Changer
 MoDiC - Mobile Diagnostic Computer
 MOST-Bus - Media Oriented System Transport bus
 MRS - Multiple Restraint System----Mehrfach-Rueckhalte-System
 MSR - engine drag torque Regulation----Motorschleppmomentregelung
 MV - Magnetic Valve (solenoid Valve)----Magnetventil
 n-ab - rotational speed, transmission (rpm)----Drehzahl der Getriebeabtriebswelle
 n-mot - rotational speed, engine (rpm)----Motordrehzahl
 NAVI - Navigation module
 NG - New Generation (as in N73 engine)
 NG - tilt sensor----Neigungssensor
 NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
 NSD - rear muffler (from ETK)----Nachschalldaempfer
 NSL - rear fog Lamp (from ETK)----Nebelschlussleuchte
 NSW - fog lamp (from ETK)----Nebellampe
 NTC - Negative Temperature Coefficient
 NW - camshaft (from ETK)----Nockenwelle
 OBC - On-Board Computer
 OBD - On-Board Diagnosis (SAE)
 P/N – Park/Neutral position
 P-Bus - Periphery bus
 PB - Pin assignments----Pinbelegung
 PBS - Parts Bulletin System (in TIS)
 PDC - Park Distance Control
 PGS - Passive Go System
 PM - Power Module
 PP – Impact Pad
 PTC - Positive Temperature Coefficient
 RLS - Rain-Light Sensor----regen-Licht-Sensor
 PWG - Pedal position sensor/ potentiometer----Pedalwertgeber
 RA - Repair instructions (in TIS)
 RAM – Random Access Memory
 RAL - Aluminum wheels (from ETK)
 RAL - standard color (from ETK)----Reichsausschuss-fuer-Lieferbedingungen
 RDC - tire pressure Control----Reifendruckkontrolle
 RDS - Radio Data-broadcast System
 RDW - tire pressure Warning----Reifendruckwarner
 RHD - Right-Hand Drive (from ETK)----Rechtslenkung
 RM - Relay Module----Relaismodul
 ROZ - Research Octane rating/ fuel grade (from ETK)
 RPA - tire puncture warning (from ETK)
 RPS - Rollover Protection System
 RS - Repair kit (from ETK)
 RSW - back-up lamp (from ETK)----Rueckfahrscheinwerfer
 RXD - wake-up Diagnosis line
 RZV - direct stationary ignition
 SASL - Satellite, A-pillar left
 SASR - Satellite, A-pillar right
 SAV - Sport ACTIVITY Vehicle
 SB - fuse assignments
 SBE - Seat occupancy detector/sensor----Sitzbelegungssensor
 SBFH - Seat module, passenger-side rear
 SBSL - Satellite, B-pillar left
 SBSR - Satellite, B-pillar right
 SBT - SI techniques/ tech reference information (in TIS)
 SCA - Soft Close Automatic/Actuator
 SD - sliding roof (from ETK)
 SD - silencer/ muffler (from ETK)----Schalldaempfer
 SE - Special Equipment (from ETK)
 SES - voice recognition System
 SFAH - Seat module, driver's side rear
 SFZ - Satellite, vehicle center
 SG - control unit
 SGS - Seat integrated belt System
 SHD - sliding/ lifting roof (from ETK)----Schiebe-Hubdach
 SHD - Sunroof module (also SHDM)
 SI - Service Information (in TIS)
 SIA - Service Interval system (ver. I, II, III, IV, etc.)
 SII - Service Interval Indicator
 SIL - SILicon (from ETK)
 SIM - Safety Information Module
 SINE - Siren/tilt sensor
 SKD - Steel sliding roof (from ETK)----Stahlkurbeldach
 SKHD - Steel sliding/ lifting roof (from ETK)
 SM - Seat Module
 SM/SPM - Seat/Mirror Memory
 SMBF - Seat Module, passenger side
 SMFA - Seat Module, driver's side
 SMG - Sequential Manual Gearbox----Sequentielles-Manuelles -Getriebe
 SP - Schematic
 SRA - headlight/fog light cleaning----Scheinwerferreinigungsanlage
 SRS - Supplementary Restraint System---Sitz-Rueckhaltsystem
 SSD - Steel sliding roof (from ETK)----Stahlschiebedach
 SSH - Seat Satellite, rear seat
 ST - connector views
 Steptronic - transmission shift control
 STVL - Satellite, left front door---Satellit, Tuer vorne links
 STVR - Satellite, right front door---Satellit, Tuer vorne rechts
 SVS - Speech processing System----Sprachverarbeitungssystem
 SWR - headlamp cleaning system (from ETK)----Scheinwerferreinigungsanlage
 SWZ - Special tool listings (in TIS)----Spezialwerkzeug
 SZL - Switch center, steering column
 SZM - central switch center Module
 TAGE - door handle Electronics
 TCM - Transmission Control Module
 TD - engine speed signal (ignition pulse)
 TD - Technical Data (in TIS)
 TDD - Technical Documentation Disk. Made availble to consumers and dealers by force of the DOT/EPA regulations for servicing the electrical and mechanical components of the emissions replated systems on the cars that are not on the ETM.
 TE - fuel evaporation control----Tankentlueftung
 TEL - TELephone control unit
 TEV - evaporative purge control----Tankentlueftungsventil
 THZ - Tandem master cylinder (from ETK)----Tandemhauptzylinder
 ti - Injector "on" Time (duration)----transmittierende Injektion (Einspritzung)
 TIS - Technical Information System
 TL - part throttle / load signal----Teillast
 TLEV - Transitional Low Emission Vehicle
 TMBFT - door Module, passenger side
 TMBFTH - door Module, passenger side rear
 TMFAT - door Module, driver's side
 TMFATH - door Module, driver's side rear
 TP - Tandem Pump (from ETK)
 TPS - Throttle Position Switch/Sensor
 TR - engine speed signal (rpm)
 TR - TRansistor (from ETK)
 TRG - fuel level sensor (from ETK)----Treibstoffstandgeber
 TRI - Technical Reference Information (also SBT)
 TRS - battery isolation Switch
 TSD - Torsional vibration dampener (from ETK)
 TSB - Technical Service Bulletin
 TSH - door lock Heating----Tuerschlossheizung
 TSZI - Transistorized coil Ignition system (from ETK)----Transistorspulenzuendung
 TU - Technical Update (as in M50tu)
 TXD - Transmitting Diagnosis line
 U-batt - Battery voltage----Batteriespannung
 U-vers - supply voltage----Spannungsversorgung
 UERSS - rollover bar (from ETK)----Ueberrollschutz
 URS - rollover protection System
 USIS - Ultrasonic passenger compartment Sensor
 V - "front" (Vorn)
 V - vehicle road speed----Geschwindigkeit
 VA - front Axle (from ETK)----Vorderachse
 VAT - front axle support (from ETK)----Vorderachstraeger
 VANOS - Variable camshaft timing----Variable Nockenwellensteuerung
 VEP - distributor-type injection Pump (from ETK)----Verteilereinspritzpumpe
 VID - VIDeo module
 VL - full load (wide open throttle)----Volllast
 VSD - front muffler (from ETK)----Vorschalldaempfer
 VVT – Valve tronic
 WBG - hazard warning switch (from ETK)----Warnblinkanlage
 WIM - Wiper control Module
 WK - torque converter lock-up clutch----Wandlerueberbrueckungskupplung
 WSS – Wind Shield (from ETK)----Windschutzscheibe
 WT – Valve tronic control unit
 Z - "central" (Zentrum)
 ZAB - ignition fade-out (reduction)
 ZAE - central Airbag Electronics
 ZAS - ignition starter switch (from ETK)----Zuend-Anlass-Schalter
 ZGM - central Gateway Module
 ZK - cylinder head (from ETK)----Zylinderkopf
 ZKE - central body Electronics----Zentrale Karosserie Elektronik
 ZKH - cylinder head cover (from ETK)----Zylinderkopfhaube
 ZMS - dual-Mass flywheel (from ETK)----Zweimassenschwungrad
 ZV - central locking system----Zentralverriegelung
 ZS - central lock (from ETK)----Zentralschluessel
 ZSD - center muffler (from ETK)----Zentral(mittel)schalldaempfer
 ZV - central locking system (from ETK)
 ZVM - central locking Module----Zentralverriegelungsmodul
 ZWD - idle control valve
 Teil 2: E*T*K*
 AB    Airbag    Airbag
 ABE    Allgemeine Betriebserlaubnis    Allgemeine Betriebserlaubnis
 ABS    Anti-Blockiersystem    Antiblockiersystem
 AC    Air Conditioning    Klimaanlage
 ACC    Adaptive Cruise Control    Adaptive Geschwindigkeitsregelung
 ACEA    Association des Constructeurs Européens     Verband europäischer Automobilhersteller
 ACM    Accessory Control Menu    Zubehör Bedieneroberfläche
 ADB    Aktive Differential Bremse    Aktive Differenzial Bremse
 ADS    Adaptive Drosselklappen-Steuerung    Adaptive Drosselklappen-Steuerung
 AE    Austauschbar/Entfallen    austauschbar/entfallen
 AEGS    Autarke Elektronische Getriebesteuerung    Autarke Elektronische Getriebesteuerung
 AFS    Active front steering    Aktivlenkung
 AGD    Ansauggeräschdämpfer    Ansauggeräuschdämpfer
 AGM    Absorbing Glas Material    Blei-Vlies Batterie
 AGR    Abgasrückführung    Abgasrückführung
 AGS    Adaptive Getriebesteuerung    Adaptive Getriebesteuerung
 AHK    Anhängerkupplung    Anhängerkupplung
 AHL    Adaptive Head Light    Adaptives Kurvenlicht
 AHM    Anhänger-Modul    Elektromodul
 AK    Ausgelagerter Kühler    Ausgelagerter Kühler
 AKF    Aktiv-Kohle-Filter    Aktivkohlefilter
 AKKS    Automatische Kühlklappensteuerung    Kühlklappensteuerung
 AKL    Adaptives Kurvenlicht    Adaptives Kurvenlicht
 AKS    Anpress-Kraft-Steuerung (Wischer)    Anpress-Kraft-Steuerung (Wischer)
 ALC    Adaptive Light Control    Adaptives Kurvenlicht
 AM    Amplituden-Modulation    Modulationsverfahren
 APM    Auxiliary Power Module     Zusatz Leistungselektronik
 ARI    Autoradio-Info-System    Verkehrsfunk
 ARS    Aktive Rollstabilisierung    Wankausgleich
 ASC    Automatische-Stabilitäts-Control    Automatische Stabilitäts Control
 ASC+T    ASC plus Traktionshilfe    ASC plus Traktionshilfe
 AT    Austauschteil    Austauschteil
 ATF    Automatic Transmission Fluid    Spezifikation für Getriebeöl
 AUC    Automatische Umluft Control    Automatische-Umluft-Control
 AVM    Automatischer Video-Multiplexer     Fahrerassistenzsystem
 AW    Arbeitswert    Arbeitswert
 AWE    Abweichungserlaubnis    Abweichungserlaubnis
 B    Breite    Breite
 BC    Bordcomputer    Bordcomputer
 BEV    battery powered electric vehicle    Batteriebetriebenes Elektrofahrzeug
 BFA    Beifahrerairbag    Beifahrerairbag
 BFD    Brake Force Display    Brake Force Display
 BKS    Bremsenkühlschacht    Bremsenkühlschacht
 BMS-CII    BMW-Motorsteuerung C-Motor    Motormanagement
 BMS-K    BMW Motorsteuerung K-Motor    Motormanagement
 BPS    BMW Premium Selection    BMW Premium Selection (Marketing)
 BSD    bit-serielle Datenschnittstelle     CO2 Massnahme
 BT    Bildtafel    Bildtafel
 BTE    Bild-Text-Einheit    Graphik mit Teileverwendungsinfo
 BVA    Bremsverschleiss-Anzeige    Bremsverschleissanzeige
 BVM    Behälterverpackungsmenge    Behälterverpackungsmenge
 Bi-Xenon    Abblend- und Fernlicht    Abblend- und Fernlicht
 CAK    Crash Aktive Kopfstütze    Crash-aktive Kopfstütze
 CAN    Datenleitung-Bordelektronik    Datenleitung-Bordelektronik
 CAS    Car Access System    Komfortzugang
 CBC    Cornering Brake Control    Cornering Brake Control
 CCC    Car Communication Computer    Car Communication Computer
 CD    Compact Disc    Compact Disc
 CF    Compact Flash    Speicherkartenformat
 CFK    Kohlefaserverstärkter Kunststoff     Carbonfaser
 CHAMP    Central Headunit Multimedia Plattform    Multimediaplattform
 CIC    Car Infotainment Computer    Communication Center
 CID    Central Information Display    Central Information Display
 CIS    Capacitive Interior Sensing    Sitzbelegungserkennung
 CL    Comfort Line    Comfort Line
 CTM    Cabrio-Top-Modul    Elektromodul
 CVM    Cabrio-Verdeck-Modul    Steuergerät
 CVT    Continuously Variable Transmission    Automatikgetriebe
 D    Durchmesser    Durchmesser
 D1    Xenon-Licht    Xenon-Licht
 DAB    Digital Audio Broadcasting    Digitalradio
 DBC    Dynamic Brake Control    Dynamische Bremsen Kontrolle
 DC    Direct Current    Gleichstrom
 DDE    Digitale Diesel Elektronik    Digitale Diesel Elektronik
 DFBS    Dieselfehlbetankungsschutz    Schutz gegen Fehlbetankung
 DFK    Doppel-Flachfederkontakt    Stecksystem
 DIN    Deutsche Industrienorm    Deutsche Industrienorm
 DKG    Doppelkupplungsgetriebe    Gertriebe M3
 DME    Digitale Motor Elektronik    Digitale Motor Elektronik
 DOT    Department of Transportation    USA-Verkehrsministerium
 DPC    Dynamik Performance Control    Antriebsmomentverteilung
 DPF    Dieselpartikelfilter    Russpartikelfilter
 DS    Dichtungssatz    Dichtungssatz
 DSC    Dynamische Stabilitäts Control    Dynamische-Stabilitäts-Control
 DSP    Digital Sound Processing    Digitaler Sound Prozessor
 DTC    Dynamische Traktions Control    Antischlupfregelung
 DVD    Digital Versatile Disc    Digital Versatile Disc
 DWA    Diebstahlwarnanlage    Diebstahlwarnanlage
 DXC    Dynamic X Control    Fahrdynamikregelung bei Allradfahrzeugen
 E    Entfallen    entfallen (nicht mehr lieferbar)
 E-Masch.    E-Maschine    Elektrische Maschine
 EBA    Einbauanleitung    Einbauanleitung
 EC    Elektrochrom    Elektrochromtechnologie
 ECE    Economic Commission for Europe    spezifische Katalogausführung
 EDC    Electronic Damper Control    Elektronische Dämpfer Kontrolle
 EH    Elektro-Hydraulisch    Elektrohydraulischer Antrieb
 EKK    Elektrischer Klimakompressor    Kompressor
 ELA    Einzelleiter Abdichtung    Feuchtigkeitsschutzstecker
 ELV    Elektrische Lenksäulenverriegelung    Elektrische Lenksäulenverriegelung
 EMF    Elektromechanische Feststellbremse    Elektromechanische Feststellbremse
 EML    Elektronische Motorleistungs Regelung    Elektronische Motorleistungsregelung
 EPB    Elektrische Parkbremse    Elektrische Parkbremse
 EPROM    Erasable Programmable Read Only Memory    Speicherchip (Steuergerät)
 EPS    Electronic Power Steering    elektrisch unterstützte Lenkung
 ESA    Electronic Suspension Adjustment    Elektronische Dämpfereinstellung
 ESD    Electrostatic Discharge    Elektrostatische Entladung
 ESL    Einschichtlackierung    Lackierung
 ETC    Electronic Toll Collection    Autobahngebührenregistrierung
 ETK    Elektronischer Teilekatalog    Elektronischer Teilekatalog
 EWB    Extended Wheel Base    Langversion
 EWS    Elektronische Wegfahrsperre    Elektronische Wegfahrsperre
 FAKRA    Normenausschuss Kraftfahrzeuge    Fachnormenausschuss Kraftfahrzeuge
 FBD    Fernbedienung    Fernbedienung
 FCD    Floating Car Data    Echtzeitverkehrsleitsystem
 FCKW    Fluorchlorkohlenwasserstoff -->R12    Fluorchlorkohlenwasserstoff
 FDC    Fahrdynamik Control    Antriebssystem
 FG    Funktionsgruppe    Funktionsgruppe
 FG ->    Ab Fahrgestellnummer    Fahrgestellnummer (VIN)
 FIBAS    Farbbild-Austast Sychronsignal    Farbbildsignal
 FLA    Fernlichtassistent    Fahrerassistenzsystem
 FRM    Fussraum Modul    Steuergerät für Karosseriefunktionen
 FRU    Flat Rate Unit    Arbeitswert
 FSC    Freischaltcode    Freischaltcode
 FU    Frisch-/Umluft    Luftaustritt
 FZD    Funktionszentrum Dach    Karosseriesteuergerät
 Funk    Funkfernbedienung    Spiegelfunktion
 GAL    Geschw.abh.Lautstärkeregelung    Geschwindig.abhängige Lautstärkeregelung
 GM    Grundmodul    Grundmodul
 GOeK    Getriebeölkühler    Getriebeölkühler
 GPS    Global Positioning System    Navigationssystem
 GSM    Global System for Mobile Communication     Kommunikationssystem
 GTO    Gate Turn Off    Garagentoröffner
 GWS    Gangwahlschaltung    Automatik
 H2    Wasserstoff    Wasserstoff
 HA    Hinterachse    Hinterachse
 HAG    Hinterachsgetriebe    Hinterachsgetriebe
 HC    Heading Control    Assistenzsystem
 HD    Heavy Duty    Erschwerter Einsatz
 HDC    Hill-Descent-Control    Bergabfahrhilfe
 HF    Hochfrequenz    Hochfrequenz
 HFM    Heissfilm-Luftmassenmesser    Luftmassenmesser
 HG    Hauptgruppe    Hauptgruppe
 HP    High Performance    High Performance
 HS    Handschaltung    Handschalter
 HSG     Hör-Sprech-Gerät    Gegensprechanlage
 HSR    Hinterachs-Schräglaufregelung     Fahrwerk
 HU'D    Head-Up Display    Head-Up Display
 HV    High Voltage    Hochvolt-System
 HWS    Hinweisschild    Schild
 I    Übersetzungsverhältnis    Übersetzungsverhältnis
 I-ABS    Integral ABS    Antiblockiersystem
 IBOC    In Band On Channel    Digitalradio USA
 IBS    Intelligenter Batteriesensor    Batteriesensor
 ICM    Integrated Chassis Management     Integrated Chasis Management
 ICOM    Integrated Comminication Optical Module    Integrated Comminication Optical Module
 ICS    Indoor communication system     Indoor communication system (Marketing)
 IHKA    Integrierte Heiz-Klima-Automatik    Integrierte Heiz-Klima-Automatik
 IHKAF    Integrierte Heiz-Klima-Automatik + MF    Integrierte Heiz-Klima-Automatik + MF
 IHKR    Integrierte Heiz-Klima-Regelung    Integrierte Heiz-Klima-Regelung
 IHKRF    Integrierte Heiz-Klima-Automatik + MF    Integrierte Heiz-Klima-Automatik + MF
 IHR    Integrierte Heizungs-Regelung    Integrierte Heizungs-Regelung
 IHRF    Integrierte Heizungs-Regelung plus MF    Integrierte Heizungs-Regelung plus MF
 IKT    Informations-/Kommunikationstechnologie    Informations-/Kommunikationstechnologie
 IMS    Instant Mobility System    Instant Mobility System
 ISA    Innensternangriff    Schraubtechnik
 ISIS    Integrated Service Information Server    HW-Basis für ETK und Servicedaten
 ISO    Isolationsüberwachung    Isolationsüberwachung
 ISPA    Integrated Service Processes Application    Werkstattplanungssystem
 ITS    Inflatable Tubular Structure    Kopfairbag
 Indi.    Individual    Individual
 JCW    John Cooper Works    JCW
 JPT    Junior Power Timer    Steckkontaktsystem
 KA    Klimaanlage    Klimaanlage
 KAT    Katalysator    Katalysator
 KBA    Kraftfahrt-Bundesamt    Kraftfahrt-Bundesamt
 KG    Kurbelgehäuse    Kurbelgehäuse
 KKB    Komplettkabelbaum    Komplettkabelbaum
 KM    Kühlmittel    Kühlmittel
 KSK    Kundenspezifischer Kabelbaum    Kundenspezifischer Kabelbaum
 KW    Kilowatt    Kilowatt
 KaFAS    Kamerabasierende Fahrerassistenzsysteme     Assistenzsystem
 Kompass    Digitale Kompassanzeige    Spiegelfunktion
 L    Länge    Länge
 LAZ    Lagerzeit    Lagerzeit
 LBV    Lehnenbreitenverstellung    Lehnenbreitenverstellung dynamisch
 LCI    Life Cycle Impulse    Modellüberarbeitung
 LCPA    LIN-Controlled Power Amplifier    Leistungsverstärker
 LDM    Längsdynamik-Management     Fahrdynamikregelung bei Allradfahrzeugen
 LED    Light Emitting Diode    Leuchtdiode
 LH    Left Hand    Linke Seite
 LHD    Left-Hand-Drive     Linkslenker
 LIN    Local Interconnection Network    Vernetzung von Steuergeräten
 LOM    Licht-Optik-Modul    Batterieüberwachung
 LRR    Long Range Radar    Radarsystem
 LSC    Leichtbauweise-Stahl-Compact    Leichtbauweise
 LSK    Laststrom-Kontakt    Stecksystem
 LVDS    Low Voltage Differential Signal    Schnelle Datenübertragung
 LVM    Lagerverpackungsmenge    Lagerverpackungsmenge
 LWL    Lichtwellenleiter    Lichtwellenleiter
 LWR    Leuchtweitenregulierung    Leuchtweitenregulierung
 M    Manuelles Getriebe    Schaltgetriebe
 MAK    Modular Automobil Kontakt    Stecksystem
 MAM    Mindestabnahmemenge    Mindestabnahmemenge
 MASK    Multimedia Audio System Kontroller    Multimedia-Audiosystem-Kontroller
 MCON    Multicontakt    Stecksystem
 MDK    Miniatur Doppelflachfeder Kontakt    Steckkontaktsystem
 MF    Mikrofilter    Mikrofilter
 MFL    Multifunktionslenkrad    Multifunktionslenkrad
 MID    Multi Information Display    Multiinformationsdisplay
 MLK    Mini Lamellen Kontakt    Kontaktstecksystem
 MOST    Media Oriented System Transport     Bus-System
 MOeK    Motorölkühler    Motorölkühler
 MPQ    Micro-Power-Quadlock    Stecksystem
 MQS    Micro-Quadlock-System    Stecksystem
 MSA    Motor-Start/Stop-Automatik    CO2 Massnahme
 MULF    MOST-univers.Lade-/Freisprecheinrichtung    Lade-/Freisprecheinrichtung
 MÜ    Modellüberarbeitung    Modellüberarbeitung
 NOX    Stickoxid    Abgas
 NSD    Nachschalldämpfer    Nachschalldämpfer
 NVC    Night Vision Camera    Nachtsichtkamera
 NoS    No Stock    Teil zentral nicht lagernd.
 OBD    On-Board-Diagnose    Diagnose-System
 OCS     Outdoor communication system     Outdoor communication system (Marketing)
 OGW    Onboard-Diagnostic-Gateway    Diagnoseanschluss
 PAV/PAX    Pneu Acrosach Vertical    Reifenstützring
 PD    Paris-Dakar    Ralleyveranstaltung
 PDC    Park Distance Control    Einparkhilfe
 PEB    Power Electonic Box     Leistungselektronik
 PEU    Power Electronics Unit    Stromverteiler
 PGS    Passive Go Steuergerät     Fahrererkennung
 PI    Produktinformation    Produktinformation
 PLATO    Planungstool    Planungstool für Zubehör
 PLCD    PermanentmagnetLinearContactlessDisplace    Sensor Leergaserkennung
 POI    Points of Interest    Orte von Interesse
 PT-Schr.    Markenname    Gewindeformende Schraube für Kunststoffe
 PTC    Positive Temperature Coefficient    Thermistor
 PTT    push to talk     Spracheingabe
 QL    Quer- und Längsdynamik     Fahrdynamikregelung
 R    Rechtslenker    Rechtslenker
 R12    FCKW-haltiges Kältemittel    FCKW-haltiges Kältemittel
 R134A    FCKW-freies Kältemittel    FCKW-freies Kältemittel
 RAL    Reichsauschuss für Lieferbedingungen    Farbnorm
 RDC    Reifen-Druck-Control    Reifendruckkontrolle
 RDS    Raddrehzahlsensor    Raddrehzahlsensor
 REP    Reparatursatz    Reparatursatz
 RFK    Rückfahrkamera    Rückfahrkamera
 RFT    Run Flat Technologie    Bereifung mit Notlaufsystem
 RH    Right Hand    Rechte Seite
 RHD    Right-Hand-Drive    Rechtslenker
 RHT    Retractable Hardtop    Hardtop versenkbar
 RKLE    Rundumkennleuchte    Rundumkennleuchte
 RLS    Regen-/Lichtsensor    Beleuchtung
 ROC    Roll Over Control     Überrollschutz
 ROZ    Research-Oktanzahl    Kraftstoffqualität
 RPA    Reifen-Pannen-Anzeige    Reifen Pannen Anzeige
 RS    Regensensor    Regensensor
 RSC    Runflat System Component     Bereifung mit Notlaufsystem
 RSE    Rear Seat Entertainment    Nachrüstsatz Rear Seat Entertainment
 RSI    Rear Seat Infotainment    Nachrüstsatz Rear Seat Entertainment
 RWS    Richtwinkelsatz    Karosserie Richtsystem
 RZV    Ruhende Zündspannungsverteilung    Einzelzündspulen
 SA    Sonderausstattung    Sonderausstattung
 SAF    Synthetic Axle Fluid    Hinterachs-Getriebeöl
 SAP     SIM Access Profile    Übertragungsprotokoll Bluetooth
 SAV    Sports Activity Vehicle    Sports Activity Vehicle
 SAW    Shielded access to Wireless LAN     Shielded Access to Wireless LAN
 SAZ    Sonderausstattung Zubehör    Seriennahes Zubehör
 SBA    Sensotronic Brake Actuation    Bremssystem für Hybrid
 SBK    Sicherheitsbatterieklemme    Batterieklemme
 SBT    Service-Information BMW Technik    Service-Information Technik
 SCA    Soft-Close-Automatik    Soft-Close-Automatik
 SCR    Selective Catalytic Reduction    Abgasreinigung Stickoxide
 SDARS    Satellite Digital Audio Radio Service    Satellitenempfang
 SDB    Sicherheitsdatenblatt    Sicherheitsdatenblatt
 SG    Steuergerät    Steuergerät
 SGS    Sitzintegriertes Gurtsystem    Sitzintegriertes Gurtsystem
 SI    Service-Information    Service-Information
 SIP    Schulungs- und Informationsprogramm    Schulungs- und Informationsprogramm
 SKR    Sommerkomplettrad    Sommerkomplettrad
 SLK    Sensor Lamellen Kontakt    Kontaktstecksystem
 SLP    Stromlaufplan    Stromlaufplan
 SLS    Sekundärluftsystem    Sekundärluftsystem
 SMB    Subminiatur Version B    Stecksystem Antennenleitungen
 SMG    Sequenzielles Manuelles Getriebe    Sequenzielles Manuelles Getriebe
 SML    Seitenmarkierungsleuchte    Seitenmarkierungsleuchte
 SOP    Start of Produktion    Beginn des Serieneinsatzes
 SPEG    Smart Power Electronics Gateway     Steuergerät für Karosseriefunktionen
 SRA    Scheinwerferreinigungsanlage    Scheinwerferreinigung
 SRD    Supply and Replenishment Dealership    Teilenachschubsystem
 SRP    Service-Reparatur-Pakete    Service-Reparatur-Pakete
 SRR    Short Range Radar    Radarsystem
 SRS    Safety Restraint System / Airbag    Safety Restraint System / Airbag
 SRT    Sun Reflective Technology    Infrarotreflektierendes Leder
 SSR    Sonnenschutzrollo    Sonnenschutzrollo
 STV    Sitztiefenverstellung    Sitztiefenverstellung
 SW    Schlüsselweite    Schlüsselweite
 SZ    Sonderzubehör    Sonderzubehör
 SZL    Schaltzentrum Lenksäule    Schaltzentrum Lenksäule
 TCU    Telematics Control Unit    Telematics Control Unit
 TI    Technische Information    Technische Information
 TIS    Technisches Informations System    Technisches Informationssystem
 TLC    Time to Line Crossing    Fahrerassistenzsystem
 TMC    Traffic Message Channel    Verkehrsfunk
 TPA    Telematik Plattform Accessory    Telematik Plattform Accessory
 TÜV    Technischer Überwachungs Verein    Herstellerbescheinigung
 UERSS    Überrollschutz    Überrollschutz
 UG    Untergruppe    Untergruppe
 ULF    Universelle Lade- u. Freisprecheinricht.    Universelle Lade- u. Freisprecheinricht.
 UPE    Unverbindliche Preisempfehlung    Unverbindliche Preisempfehlung
 USB    Universal Serial Bus    Universelle PC Schnittstelle
 USIS    Ultraschall Innenraumschutz    Innenraumschutz
 VA    Vorderachse    Vorderachse
 VDC    Vertical Dynamic Control     Fahrwerkstechnik
 VDD  Ventildeckeldichtung
 VDM    Vertikaldynamik Management    Fahrdynamikregelung bei Allradfahrzeugen
 VF    Verkehrsfunk    Verkehrsfunk
 VHT    Versenkbares Hardtop    Hardtop versenkbar
 VICS    Vehicle Information&Communication System    Fahrzeuginformationssystem
 VIN    Vehicle Identification Number    Fahrgestellnummer (VIN)
 VMS    Vehicle Management System    Steuergerät BEV
 VOC    Volatile Organic Compounds    Flüchtige organische Lösungsmittel
 VVM    Vorverpackungsmenge    Vorverpackungsmenge
 VVT    Variabler Ventiltrieb    Variable Ventilsteuerung
 WAPU    Wasserpumpe    Wasserpumpe
 WBA    Warnblinkanlage    Warnblinkanlage
 WKR    Winterkomplettrad    Winterkomplettrad
 WSA    Wechselsprechanlage    Wechselsprechanlage
 ZBE    Zentrales Bedienelement    iDrive Controller
 ZFE    Zentrale Fahrzeug-Elektronik    Steuergerät
 ZKD  Zylinderkopfdichtung
 ZKE    Zentrale Karrosserie-Elektronik    Steuergerät für Karosseriefunktionen
 ZKW    Zizala Karl Wien    Lieferant Lichtsysteme
 ZV    Zentralverriegelung    Zentralverriegelung
 ZWSL    Zweischichtlackierung    Lackierung
				MfG,
Norbert
 __-- Ich hab grade versucht mit dem Mauszeiger ne Fliege vom Bildschirm zu vertreiben! Ich glaub, ich brauch Urlaub...--__ ------------------
				 Geändert von nordberg (06.10.2011 um 22:17 Uhr).
						Grund: Teil 2 ergänzt
		 Linear-Darstellung |
	|  Forumregeln |
 HTML-Code ist aus. |  |  |  |
