Zurück   BMW 7er-Forum > BMW 7er Modelle > BMW 7er, allgemein > 7er, allgemein: Tipps & Tricks
Alt 21.03.2003, 14:50   #1
Standard Modellreihen und Motorbezeichnungen
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) von BMW, Honda, Mazda, Opel
Alt 03.04.2003, 10:57   #2
JB740
the Senior :-)
Benutzerbild von JB740
Fahrzeug: 740i, Bj 03/17
Standard Erich
maaano Erich, wo kramst du das nur immer alles raus?????
L 7 weiss dann ja endlich, dass er einen XL fährt
gruss und danke für die guten Tipps,
jürgen
Alt 17.10.2003, 19:07   #3
Standard Neueste Daten
Model and engine designations
Vehicle designations
114 1602 - 2002 tii
118 1500, 1600-4, 1800, 1800tii
120 2000C/CS/CA
121 2000, 2000 ti, 2000tilux
E3 2500 - 3.3 Li
E6 1600, 1800, 2000 touring
E9 2500 CS - 3.0 CSi
E12 5 series up to 81 year model (80 model year in Europe)
E12/5 As above with M60 engine (not V8)
E12/6 As above with M68 engine
E12/8 As above for South Africa
E21 3 series up to 83 year model
E21/5 3 series with M60 (not V8)
E23 7 series up to 87 model year (86 Model year in Europe)
E24 6 series
E26 M1
E28 5 series from 82 year model (81 model in Europe)
E30 3 series from 84 year model
E31 8 series
E32 7 series from 88 year model (87 year model in Europe)
E34 5 series from 89 year model (88 year model in Europe)
E36 3 series from 92 year model
E36/5 3 series hatchback
E36/7 Z3 Roadster
E38 7 series from 95 year model
E39 5 series from 97 year model (96 outside US)
E46 3 series, 4 door from 1999, Coupe from 2000
E52 Z8 Roadster
E53 X5 SAV
E65 7 series short wheel base from 2002.
E66 7 series long wheel base from 2002
E85 Z4 Roadster
Old engine codes, no longer used
M41 4 cylinder 1.6 litre, DIDTA carburetor
M42 4 cylinder 1.8 litre, DIDTA carburetor
M49 6 cylinder 3.4 litre 24 valve Motorsport twin cam.
M60 6 cylinder 2.0 and 2.3 litre carburetor or fuel injected
M68 6 cylinder 2.5 - 2.8 litre carburetor
M69 6 cylinder 3.2 litre fuel injection
M86 6 cylinder 2.8 litre fuel injection (L Jetronic)
M90 6 cylinder 3.5 litre
M92 4 cylinder 1.8 litre K Jetronic fuel injection
M99 4 cylinder 1.8 litre 2B4 carburetor
M102 6 cylinder 3.2 litre turbocharged
Current engine designations
M10 1.8 or 2.0 litre 4 cylinder single overhead cam , timing chain
M20 2.0, 2.3, 2.5 or 2.7 litre 6 cylinder single overhead cam , timing belt
M21 6 cylinder diesel, 2.4 litre single overhead cam, timing belt. Naturally aspirated or turbocharged.
M30 2.8, 3.0, 3.2 or 3.4 litre 6 cylinder single overhead cam, timing chain. Available with turbocharger
M40 4 cylinder single overhead cam, timing belt
M41 4 cylinder diesel
M42 1.8 litre 4 cylinder dual overhead cam
M43 4 cylinder
M44 1.9 litre 4 cylinder 4 valves
M50 2.0, 2.3 or 2.5 litre 6 cylinder dual overhead cam
M50TU 2.0, 2.3 or 2.5 litre 6 cylinder dual overhead cam, variable intake (VaNoS)
M51 6 cylinder diesel
M52 2.0, 2.3, 2.5 or 2.8 litre 6 cylinder dual overhead cam, variable intake (VaNoS)
M52TU 2.5 and 3.0 litre 6 cylinder dual overhead cam, dual VaNoS
M54 2.5 and 3.0 litre 6 cylinder dual overhead cam, dual VaNoS
M56 2.5 litre 6 cylinder dual overhead cam, dual VaNoS, SULEV (super ultra low emissions vehicle)
M60 V8 3.0 or 4.0 litre
M62 V8 3.5 or 4.4 litre
M70 V12 5.0 litre
M73 V12 5.4 litre
M88 6 cylinder 3.5 litre 24 valve Motorsport engine found in M1 only
M88/3 As above for all other vehicles
S14 2.3 litre 4 cylinder dual overhead cam M power
S38 3.6 or 3.8 litre 6 cylinder dual overhead cam M power
S50 3.0 or 3.2 litre 6 cylinder dual overhead cam M power, dual variable cams (VaNoS) (Non US E36 M3)
S50US 3.0 litre 6 cylinder dual overhead cam M power, variable intake cam (VaNoS)
S52 3.2 litre 6 cylinder dual overhead cam M power, variable intake cam (VaNoS) US market only.
S54 3.2 litre 6 cylinder dual overhead cam M power, dual variable cams
S62 5.0 litre V8 M power quad VaNoS 400hp.
S70 5.6 litre V12 M power
Engine designations are followed by a capacity code, e.g.. M20B25 is an M20 engine, of 2.5 litre capacity.
Vehicle designations are occasionally followed by a variant, e.g. E36/7 is the Z3 roadster.
Alt 21.01.2005, 12:00   #4
7er-M-74
Fahrzeug: 525D E39
Und was ist mit dem M57 motor
habe ich etwa keinen motor drin in der liste steht er nicht drin
laut BMW VIN Decoder habe ich den M57 motor verbaut
7er-M-74 ist offline   Antwort Mit Zitat antworten
Alt 21.01.2005, 13:46   #5
Fahrzeug- Typ Bj Hubraum Motor KW / PS
X5 3,0 TDS 04/00- 2926 M57 D30 6 Zyl. 135 / 184
745I (E23) 4/80-8/86 3210 M30 B32 Turbo / M30 B35 185 / 252
524TD ( E28) 9/83-12/87 2443 M21 D24 6 Zyl. 85 / 115
324 TD/Touring (E30) 9/87-6/93 2443 M21 D24 6 Zyl. 85 / 115
524TD (E34) 3/88-9/95 2443 M21 D24 6 Zyl. 85 / 115
525 TD / Touring (E34) 3/93-1/97 2497 M51 D25 6 Zyl. 85 / 115
525 TDS / Touring (E34) 9/91-1/97 2503 M51 D25 6 Zyl. 105 / 143
325 TD (E36) 9/91-12/95 2497 M51 D25 6 Zyl. 85 / 115
325 TD (E36) 1/96-2/98 2497 M51 D25 6 Zyl. 85 / 115
325 TDS / Touring (E36) 5/93-10/99 2503 M51 D25 6 Zyl. 105 / 143
318 TDS/Comp./Tour. ( E36) 1/95- 1665 M41 D18 4 Zyl. 66 / 90
525 TDS / Touring (E39) 1/96- 2503 M51 D25 6 Zyl. 105 / 143
725 TDS (E38) 4/96- 2503 M51 D25 6 Zyl. 105 / 143
525 TD (E39) 1/97- 2497 M51 D25 6 Zyl. 85 / 115
320 D / Touring ( E46) 4/98- 1951 M47 D20 4 Zyl. 100 / 136
530 D (E39) 8/98-9/00 2926 M57 D30 6 Zyl. 135 / 184
730 D (E38) 8/98-4/00 2926 M57 D30 6 Zyl. 135 / 184
740 D (E38) 5/99- 3901 M67D V8 Zyl. 180 / 245
330 D / Touring (E46) 10/99- 2926 M57 D30 6 Zyl. 135 / 184
Alt 21.01.2005, 13:52   #6
7er-M-74
Fahrzeug: 525D E39
mist doch vorhanden und ich dachte ich habe einen geheimen motor drin wieder nichts
Alle Zeitangaben in WEZ +1. Es ist jetzt 15:54 Uhr.
