06.10.2011, 21:04
Eyes Wide Shut
Fahrzeug: E38 740iA PD 09/95
Techn. Begriffserklärungen rund um alle 7er - Abkürzungen aufgeschlüsselt
@Knuffel
Du meinst so ne kurze, übersichtliche, Auflistung?
Sind zwei Teile.
Teil 1: Englisch (teilweise mit deutschen Begriffen ergänzt)(Wie die Lottozahlen in den Nachrichten: Ohne Peng, ähh... Gewähr!  )
Teil 2: Deutsch (Quelle E*T*K*)
Teil 1 Glossary of BMW Terms and Abbreviations
A - processed vehicle speed signal
A - "out" (Aus)
AB - Airbag
ABL - Brake system warning Lamp (2 color)
ABS - Anti-lock Braking System----Antiblockiersystem
AC - Air Conditioning (from ETK)
ACC - Active Cruise Control
ACS - Active Comfort Seats
ADB(X) - Automatic Differential Braking
ADS - engine intake air control
ADV - windshield wiper pressure control----Anpressdruckverstellung
AEGS - Automatic Electronic Gearbox Control (also EGS)
AFM - Air Flow Meter----Luftmengenmesser
AGD - suction silencer (from ETK)----Ansauggeraeuschdaempfer
AGR - emission reduction
AGS - Adaptive transmission control----adaptive Getriebesteuerung
AG - Automatic Gearbox (transmission)----automatisches Getriebe
AHK - Active rear-axle Kinematics
AHK - trailer hitch (from ETK)----Anhaengerkupplung
AHM - trailer Module (not for US models)
AHPS - Advanced HPS
AIC - Automatic Interval Control (rain sensor)
AKF - activated carbon canister (from ETK)
AKS - Active head restraint
AKS - pressure regulating device (from ETK)
ALC - Automatic Light Control
ALR - Automatic Lamp Range Adjustment
AMM - Air Mass Meter----Luftmassenmesser
AMP - radio system AMPlifier
ARI - car radio information system (from ETK)
ARS - Active Roll Stabilization
ASC - All Season traction
ASC-EZA - ASC w/ engine timing and injection intervention
ASC+T - ASC+ Traction control
ASK - Audio System controller (Kontroller)
ASR - self starter block relay (from ETK)
AST - Automatic Slip control (marketing term)
AT - remanufactured part (from ETK)
AT - Antenna (from ETK)
ATF - Automatic Transmission Fluid (from ETK)
ATL - exhaust gas turbo charger (from ETK)----Abgasturbolader
AUC - Automatic air recirculation
AUT - AUTomatic transmission (from ETK)
AVT - Antenna amplifier Tuner
AZD - tightening torque specifications (in TIS)
A/D – Analog/Digital
B - Benzene (gasoline)----Benzin
BAT - BATtery (from ETK)
BC - Board Computer
BC1 - Body Controller 1
BL - Brake Light (from ETK)----Bremslicht
BLS - Brake Light Switch----Bremslichtschalter
Bluetooth - A wireless interconnection technology that automatically recognizes and communicates with components (such as cell phones, headsets and computing devices) when brought into close proximity (generally 30 feet or less).
BMBT - Board Monitor
BS - Block diagram
BST - Battery Safety Terminal
BVA - Brake pad wear indicator (from ETK)----Bremsbelagverschleissanzeiger
BZM - center console control center
BZMF - center console control center, rear
CAN – Controller Area Network (Multiple ECU Controller)
CAN-Bus - Controller Area Network (bus)
CANH-Bus - CAN bus, High
CANL-Bus - CAN bus, Low
CANP - fuel tank ventilation valve
CAS - Car Access System
CBC - Corner Braking Control
CBS - Condition Based Service
CCM - Check Control Module
CD - Control Display
CDC - Compact Disk Changer
CDS - CD player (from ETK)
CEL - CELsius (from ETK)
CIM - Chassis Integration Module
CO - Carbon monOxide (from ETK)
COMBI – Electronic Instrument Cluster
CON - CONtroller
CU - Copper (from ETK)----Kupfer
CVM - Convertible top Module
CVT - Constantly Variable Transmission
CW - drag coefficient (from ETK)----Luftwiderstandsbeiwert
CWP - Cold Weather Package
D1 - Xenon light/ gas discharge (from ETK)
D-Bus - Diagnosis bus (same as TXD)
DBC - Dynamic Brake Control
DBS - Dynamic Braking System
DCS - Dealer Communication System
DE – Diagnostic Unit----Diagnoseeinheit
DD - Dynamic motor Drive
DDE - Digital Diesel Electronics
DIN - German industrial standards
DIS - Diagnosis and Information System
DISA - Differential air intake control
DIVA - continuously variable length intake runners
DK - throttle housing/valve----Drosselklappe
DKB - throttle w/ brake intervention
DKE – Throttle Increase
DKI - throttle position
DKR - throttle reduction
DKT - throttle position signal
DKV - preset throttle position value
DME - Digital Motor Electronics
DM-TL - Diagnostic Module Tank Leakage
DOHC - Double Over Head Camshafts (from ETK)----doppelte obenliegende Nockenwelle
DS - gasket set (from ETK)----Dichtungssatz
DSC - Dynamic Stability Control
DSP - Digital Sound Processing
DTC - Diagnostic Trouble Code (SAE)
DTC - Dynamic Traction Control
DWA - theft deterrent system----Diebstahlwarnanlage
DWS - tire pressure Warning System----Druckwarnsystem
DZM - revolution counter (from ETK)----Drehzahlmesser
E - "in" (Ein)
EBA - EinBau Anleitung (translated Installation Instructions). This is a CD-ROM with installation instructions for various options and upgrades.
EBV - Electronic Brake force proportioning----elektronisches Bremsventil
ECE - European market version (from ETK)
ECM - Engine Control Module (SAE term)
ECU - Electronic Control Unit
EDC - Electronic Damper Control (from ETK)
EDR - Electronic throttle control----elektronische Drehzahlregelung
E-KAT - Electrically heated catalytic converter----beheizter KAT
EZA - see ASC-EZA
ECO - Controller for I-Drive system
EDC - Electronic Dampening Control----elektronische Daempferkontrolle
EDC-K - Electronic Dampening Control - Continuous
EDK - Electronic throttle valve----elektronische Drosselklappe
EDS - pressure regulator----Druckspeicher
EFH - Electric window lifter (from ETK)----elektrische Fensterheber
EGS - Electronic transmission control----elektronische Getriebesteuerung
EH - Electronic-Hydraulic
EHC - Electronic Height Control
EKM - Electronic body Module----elektronisches Karosserie Modul
EKP - Electric fuel Pump----elektrische Kraftstoffpumpe
ELV - Electronic steering lock----elektronische Lenkradverriegelung
EM - Electro-Mechanical----elektro-mechanisch
EMF - Electro-Mechanical parking brake----elektro-mechanische Fussbremse
EML - Electronic Motor Load regulation----Elektronische Motorlastregelung
EMV - Electro-Magnetic sensitivity (from ETK)---elektromagnetische Vertraeglichkeit
EO - component location----Einbauort
EPC - Electronic Parts Catalog (also ETK)
EPROM - Erasable/ Programmable chip Memory (from ETK)
ETK - Electronic parts catalog (also EPC)----Ersatzteilkatalog
ETM - Electrical Troubleshooting Manual
ESS - Electronic anti-theft device----Elektronisches Sicherheits System
EV - injection Valve----Einspritzventil
EWS - Electronic drive-away protection----Elektronische Wegfahrsperre
FB - Function description----Funktionsbeschreibung
FBC - Fading Brake Control
FBD - remote control services----Fernbedienung
FBZV - radio frequency locking system
FGR – Vehicle Speed Control (Cruise Control)----Fahrzeuggesxchwindi
FH - window lifter----Fensterheber
FHK - rear Heater/ air conditioner
FLC - automatic Light Control
FRU - Flat Rate Unit
FS – Crash Sensor
FZV - central lock receiver
GAL - speed dependent sound volume----geschwindigkeitsabhaengige Lautstaerkeregelung
GM - General Module----Grundmodul
GMR - yaw moment control----Giermomentregelung
GPS - Global Positioning System
GRII - cruise control----Geschwindigkeitsregelung II (Tempomat)
GRS - rotation Rate Sensor
GS – Belt Tensioner
GWK - torque converter lock-up control
H - "rear" (Hinten)
H2 - Xenon headlights
HA - rear Axle (from ETK)----Hinterachse
HC – Hydro Carbon
HD - Heavy Duty (from ETK)
HDC - Hill Decent Control
HFM - Hot Film air mass Meter----Heissfilmluftmengenmesser
HG - manual Gearbox (transmission)----Handschaltgetriebe
HKL - Hydraulic trunk lid Lift----hydraulischer Kofferraumdeckellifter
HLM – Hot Wire Air Mass Meter----Heissdrahtluftmengenmesser
HPS - Head Protection System
HR - Heater control (from ETK)----Heizungsregelung
HVA - Hydraulic Valve Adjuster (from ETK)
Hz – Hertz (Cycle)
I-Bus - Information bus
IB - Interior lighting control signal
IHKA - automatic Heating and A/C
IHKAF - IHKA w/ micro filter
IHKR - regulated Heating and A/C----Integrierte Heizungs-Klimaregler
IHKRF - IHKR w/ micro filter
IHKS - standard Heating and A/C----Integrierte Heizungs-Klimasteuerung
IHPD - Internal High Pressure Deformation
IHR - Integrated Heater control (from ETK)----integrierte Heizungsregelung
IKE - Instrument cluster Electronics
ILH - Interior Lighting, rear----Innenlicht, hinten
ILV - Interior Lighting, front----Innenlicht, vorne
IMS - Instant Mobility System (from ETK)
IR – Infrared
IRS – Infrared Locking System
ISC – Idle Speed Control
ISIS - Intelligent Safety Integration System
ISN - Individual Serial Number
ISOFIX - standardized mounts for child restraints
ITS - head airbag assembly/ Inflatable Tubular Structure
IVM - Integrated power supply Module----Integriertes Versorgungsmodul
K-Bus - body bus (Karosserie)
KAT - catalytic converter----katalysator
KATON - converter creating (signal)
KD - Kick-Down
KDS - Komputer Service Desk (Translated Computer) A CD-ROM that inlcudes the defect codes and flat rate labor units BMW allows for the warranty repair of defects.
KHI - interface for headphones----Kopfhoererinterface
KL - terminal designation----Klemme
KL15 - run bus (ignition switch run position)----Klemme 15
KL30 - battery bus (hot at all times)----Klemme 30 (Dauerplus)
KL31 - ground bus (chassis ground)----Klemme 31 (Masse)
KL50 - start bus (ignition start position)----Klemme 50
KLR - accessory bus
KO - compressor "on" signal
KOMBI - instrument cluster----Kombiinstrument (Tacho-Drehzahlmesser, usw.)
KOREL - compressor relay signal
KR – Contact Ring
KSK - Knock Sensor----Klopfsensor
KVA - fuel consumption signal/value
KW - crankshaft----Kurbelwelle
KW - KiloWatt (from ETK)
LCM - Lamp Check Module
LDP - Leak Diagnosis Pump
LEV - Low Emissions Vehicle
LEW - Lateral acceleration sensor
LHD - Left-Hand Drive (from ETK)----Linkslenker
LKM - Lamp control Module----Lampenkontrollmodul
LL - closed throttle----Leerlauf
LM - Light Module----Lichtmodul
LMM - air flow meter/sensor----Luftmengenmesser/Luftmassenmesser
LMR - Light alloy wheel----Leichtmetallrad
LRA - vertical headlight aiming----Leuchtweitenregelung
LSM - steering column memory----Lenksauelenmemory
LSZ - Lamp Switching center
LVA - air supply system (for EHC system)----Luftversorungsaggregat
LWR - vertical headlight aim control----Leuchtweitenregelung
LWS-5 - steering angle sensor----Lenkwinkersensor
M-Bus - IHKA/IHKR stepper motor bus
MAL - center armrest----Mittelarmlehne
MBC - Maximum Brake Control
MDK - Motorized throttle valve/system
MFL - Multi-Function steering wheel----Multifunktionslenkrad
MFC - Multi-Function Controller
MFU - Multi-Function Clock----Multifunktionsuhr
MID - Multi-Information Display
MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
MIR - Multi-Information Radio
MMC - Multi-Media Changer
MoDiC - Mobile Diagnostic Computer
MOST-Bus - Media Oriented System Transport bus
MRS - Multiple Restraint System----Mehrfach-Rueckhalte-System
MSR - engine drag torque Regulation----Motorschleppmomentregelung
MV - Magnetic Valve (solenoid Valve)----Magnetventil
n-ab - rotational speed, transmission (rpm)----Drehzahl der Getriebeabtriebswelle
n-mot - rotational speed, engine (rpm)----Motordrehzahl
NAVI - Navigation module
NG - New Generation (as in N73 engine)
NG - tilt sensor----Neigungssensor
NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
NSD - rear muffler (from ETK)----Nachschalldaempfer
NSL - rear fog Lamp (from ETK)----Nebelschlussleuchte
NSW - fog lamp (from ETK)----Nebellampe
NTC - Negative Temperature Coefficient
NW - camshaft (from ETK)----Nockenwelle
OBC - On-Board Computer
OBD - On-Board Diagnosis (SAE)
P/N – Park/Neutral position
P-Bus - Periphery bus
PB - Pin assignments----Pinbelegung
PBS - Parts Bulletin System (in TIS)
PDC - Park Distance Control
PGS - Passive Go System
PM - Power Module
PP – Impact Pad
PTC - Positive Temperature Coefficient
RLS - Rain-Light Sensor----regen-Licht-Sensor
PWG - Pedal position sensor/ potentiometer----Pedalwertgeber
RA - Repair instructions (in TIS)
RAM – Random Access Memory
RAL - Aluminum wheels (from ETK)
RAL - standard color (from ETK)----Reichsausschuss-fuer-Lieferbedingungen
RDC - tire pressure Control----Reifendruckkontrolle
RDS - Radio Data-broadcast System
RDW - tire pressure Warning----Reifendruckwarner
RHD - Right-Hand Drive (from ETK)----Rechtslenkung
RM - Relay Module----Relaismodul
ROZ - Research Octane rating/ fuel grade (from ETK)
RPA - tire puncture warning (from ETK)
RPS - Rollover Protection System
RS - Repair kit (from ETK)
RSW - back-up lamp (from ETK)----Rueckfahrscheinwerfer
RXD - wake-up Diagnosis line
RZV - direct stationary ignition
SASL - Satellite, A-pillar left
SASR - Satellite, A-pillar right
SAV - Sport ACTIVITY Vehicle
SB - fuse assignments
SBE - Seat occupancy detector/sensor----Sitzbelegungssensor
SBFH - Seat module, passenger-side rear
SBSL - Satellite, B-pillar left
SBSR - Satellite, B-pillar right
SBT - SI techniques/ tech reference information (in TIS)
SCA - Soft Close Automatic/Actuator
SD - sliding roof (from ETK)
SD - silencer/ muffler (from ETK)----Schalldaempfer
SE - Special Equipment (from ETK)
SES - voice recognition System
SFAH - Seat module, driver's side rear
SFZ - Satellite, vehicle center
SG - control unit
SGS - Seat integrated belt System
SHD - sliding/ lifting roof (from ETK)----Schiebe-Hubdach
SHD - Sunroof module (also SHDM)
SI - Service Information (in TIS)
SIA - Service Interval system (ver. I, II, III, IV, etc.)
SII - Service Interval Indicator
SIL - SILicon (from ETK)
SIM - Safety Information Module
SINE - Siren/tilt sensor
SKD - Steel sliding roof (from ETK)----Stahlkurbeldach
SKHD - Steel sliding/ lifting roof (from ETK)
SM - Seat Module
SM/SPM - Seat/Mirror Memory
SMBF - Seat Module, passenger side
SMFA - Seat Module, driver's side
SMG - Sequential Manual Gearbox----Sequentielles-Manuelles -Getriebe
SP - Schematic
SRA - headlight/fog light cleaning----Scheinwerferreinigungsanlage
SRS - Supplementary Restraint System---Sitz-Rueckhaltsystem
SSD - Steel sliding roof (from ETK)----Stahlschiebedach
SSH - Seat Satellite, rear seat
ST - connector views
Steptronic - transmission shift control
STVL - Satellite, left front door---Satellit, Tuer vorne links
STVR - Satellite, right front door---Satellit, Tuer vorne rechts
SVS - Speech processing System----Sprachverarbeitungssystem
SWR - headlamp cleaning system (from ETK)----Scheinwerferreinigungsanlage
SWZ - Special tool listings (in TIS)----Spezialwerkzeug
SZL - Switch center, steering column
SZM - central switch center Module
TAGE - door handle Electronics
TCM - Transmission Control Module
TD - engine speed signal (ignition pulse)
TD - Technical Data (in TIS)
TDD - Technical Documentation Disk. Made availble to consumers and dealers by force of the DOT/EPA regulations for servicing the electrical and mechanical components of the emissions replated systems on the cars that are not on the ETM.
TE - fuel evaporation control----Tankentlueftung
TEL - TELephone control unit
TEV - evaporative purge control----Tankentlueftungsventil
THZ - Tandem master cylinder (from ETK)----Tandemhauptzylinder
ti - Injector "on" Time (duration)----transmittierende Injektion (Einspritzung)
TIS - Technical Information System
TL - part throttle / load signal----Teillast
TLEV - Transitional Low Emission Vehicle
TMBFT - door Module, passenger side
TMBFTH - door Module, passenger side rear
TMFAT - door Module, driver's side
TMFATH - door Module, driver's side rear
TP - Tandem Pump (from ETK)
TPS - Throttle Position Switch/Sensor
TR - engine speed signal (rpm)
TR - TRansistor (from ETK)
TRG - fuel level sensor (from ETK)----Treibstoffstandgeber
TRI - Technical Reference Information (also SBT)
TRS - battery isolation Switch
TSD - Torsional vibration dampener (from ETK)
TSB - Technical Service Bulletin
TSH - door lock Heating----Tuerschlossheizung
TSZI - Transistorized coil Ignition system (from ETK)----Transistorspulenzuendung
TU - Technical Update (as in M50tu)
TXD - Transmitting Diagnosis line
U-batt - Battery voltage----Batteriespannung
U-vers - supply voltage----Spannungsversorgung
UERSS - rollover bar (from ETK)----Ueberrollschutz
URS - rollover protection System
USIS - Ultrasonic passenger compartment Sensor
V - "front" (Vorn)
V - vehicle road speed----Geschwindigkeit
VA - front Axle (from ETK)----Vorderachse
VAT - front axle support (from ETK)----Vorderachstraeger
VANOS - Variable camshaft timing----Variable Nockenwellensteuerung
VEP - distributor-type injection Pump (from ETK)----Verteilereinspritzpumpe
VID - VIDeo module
VL - full load (wide open throttle)----Volllast
VSD - front muffler (from ETK)----Vorschalldaempfer
VVT – Valve tronic
WBG - hazard warning switch (from ETK)----Warnblinkanlage
WIM - Wiper control Module
WK - torque converter lock-up clutch----Wandlerueberbrueckungskupplung
WSS – Wind Shield (from ETK)----Windschutzscheibe
WT – Valve tronic control unit
Z - "central" (Zentrum)
ZAB - ignition fade-out (reduction)
ZAE - central Airbag Electronics
ZAS - ignition starter switch (from ETK)----Zuend-Anlass-Schalter
ZGM - central Gateway Module
ZK - cylinder head (from ETK)----Zylinderkopf
ZKE - central body Electronics----Zentrale Karosserie Elektronik
ZKH - cylinder head cover (from ETK)----Zylinderkopfhaube
ZMS - dual-Mass flywheel (from ETK)----Zweimassenschwungrad
ZV - central locking system----Zentralverriegelung
ZS - central lock (from ETK)----Zentralschluessel
ZSD - center muffler (from ETK)----Zentral(mittel)schalldaempfer
ZV - central locking system (from ETK)
ZVM - central locking Module----Zentralverriegelungsmodul
ZWD - idle control valve
Teil 2: E*T*K*
AB Airbag Airbag
ABE Allgemeine Betriebserlaubnis Allgemeine Betriebserlaubnis
ABS Anti-Blockiersystem Antiblockiersystem
AC Air Conditioning Klimaanlage
ACC Adaptive Cruise Control Adaptive Geschwindigkeitsregelung
ACEA Association des Constructeurs Européens Verband europäischer Automobilhersteller
ACM Accessory Control Menu Zubehör Bedieneroberfläche
ADB Aktive Differential Bremse Aktive Differenzial Bremse
ADS Adaptive Drosselklappen-Steuerung Adaptive Drosselklappen-Steuerung
AE Austauschbar/Entfallen austauschbar/entfallen
AEGS Autarke Elektronische Getriebesteuerung Autarke Elektronische Getriebesteuerung
AFS Active front steering Aktivlenkung
AGD Ansauggeräschdämpfer Ansauggeräuschdämpfer
AGM Absorbing Glas Material Blei-Vlies Batterie
AGR Abgasrückführung Abgasrückführung
AGS Adaptive Getriebesteuerung Adaptive Getriebesteuerung
AHK Anhängerkupplung Anhängerkupplung
AHL Adaptive Head Light Adaptives Kurvenlicht
AHM Anhänger-Modul Elektromodul
AK Ausgelagerter Kühler Ausgelagerter Kühler
AKF Aktiv-Kohle-Filter Aktivkohlefilter
AKKS Automatische Kühlklappensteuerung Kühlklappensteuerung
AKL Adaptives Kurvenlicht Adaptives Kurvenlicht
AKS Anpress-Kraft-Steuerung (Wischer) Anpress-Kraft-Steuerung (Wischer)
ALC Adaptive Light Control Adaptives Kurvenlicht
AM Amplituden-Modulation Modulationsverfahren
APM Auxiliary Power Module Zusatz Leistungselektronik
ARI Autoradio-Info-System Verkehrsfunk
ARS Aktive Rollstabilisierung Wankausgleich
ASC Automatische-Stabilitäts-Control Automatische Stabilitäts Control
ASC+T ASC plus Traktionshilfe ASC plus Traktionshilfe
AT Austauschteil Austauschteil
ATF Automatic Transmission Fluid Spezifikation für Getriebeöl
AUC Automatische Umluft Control Automatische-Umluft-Control
AVM Automatischer Video-Multiplexer Fahrerassistenzsystem
AW Arbeitswert Arbeitswert
AWE Abweichungserlaubnis Abweichungserlaubnis
B Breite Breite
BC Bordcomputer Bordcomputer
BEV battery powered electric vehicle Batteriebetriebenes Elektrofahrzeug
BFA Beifahrerairbag Beifahrerairbag
BFD Brake Force Display Brake Force Display
BKS Bremsenkühlschacht Bremsenkühlschacht
BMS-CII BMW-Motorsteuerung C-Motor Motormanagement
BMS-K BMW Motorsteuerung K-Motor Motormanagement
BPS BMW Premium Selection BMW Premium Selection (Marketing)
BSD bit-serielle Datenschnittstelle CO2 Massnahme
BT Bildtafel Bildtafel
BTE Bild-Text-Einheit Graphik mit Teileverwendungsinfo
BVA Bremsverschleiss-Anzeige Bremsverschleissanzeige
BVM Behälterverpackungsmenge Behälterverpackungsmenge
Bi-Xenon Abblend- und Fernlicht Abblend- und Fernlicht
CAK Crash Aktive Kopfstütze Crash-aktive Kopfstütze
CAN Datenleitung-Bordelektronik Datenleitung-Bordelektronik
CAS Car Access System Komfortzugang
CBC Cornering Brake Control Cornering Brake Control
CCC Car Communication Computer Car Communication Computer
CD Compact Disc Compact Disc
CF Compact Flash Speicherkartenformat
CFK Kohlefaserverstärkter Kunststoff Carbonfaser
CHAMP Central Headunit Multimedia Plattform Multimediaplattform
CIC Car Infotainment Computer Communication Center
CID Central Information Display Central Information Display
CIS Capacitive Interior Sensing Sitzbelegungserkennung
CL Comfort Line Comfort Line
CTM Cabrio-Top-Modul Elektromodul
CVM Cabrio-Verdeck-Modul Steuergerät
CVT Continuously Variable Transmission Automatikgetriebe
D Durchmesser Durchmesser
D1 Xenon-Licht Xenon-Licht
DAB Digital Audio Broadcasting Digitalradio
DBC Dynamic Brake Control Dynamische Bremsen Kontrolle
DC Direct Current Gleichstrom
DDE Digitale Diesel Elektronik Digitale Diesel Elektronik
DFBS Dieselfehlbetankungsschutz Schutz gegen Fehlbetankung
DFK Doppel-Flachfederkontakt Stecksystem
DIN Deutsche Industrienorm Deutsche Industrienorm
DKG Doppelkupplungsgetriebe Gertriebe M3
DME Digitale Motor Elektronik Digitale Motor Elektronik
DOT Department of Transportation USA-Verkehrsministerium
DPC Dynamik Performance Control Antriebsmomentverteilung
DPF Dieselpartikelfilter Russpartikelfilter
DS Dichtungssatz Dichtungssatz
DSC Dynamische Stabilitäts Control Dynamische-Stabilitäts-Control
DSP Digital Sound Processing Digitaler Sound Prozessor
DTC Dynamische Traktions Control Antischlupfregelung
DVD Digital Versatile Disc Digital Versatile Disc
DWA Diebstahlwarnanlage Diebstahlwarnanlage
DXC Dynamic X Control Fahrdynamikregelung bei Allradfahrzeugen
E Entfallen entfallen (nicht mehr lieferbar)
E-Masch. E-Maschine Elektrische Maschine
EBA Einbauanleitung Einbauanleitung
EC Elektrochrom Elektrochromtechnologie
ECE Economic Commission for Europe spezifische Katalogausführung
EDC Electronic Damper Control Elektronische Dämpfer Kontrolle
EH Elektro-Hydraulisch Elektrohydraulischer Antrieb
EKK Elektrischer Klimakompressor Kompressor
ELA Einzelleiter Abdichtung Feuchtigkeitsschutzstecker
ELV Elektrische Lenksäulenverriegelung Elektrische Lenksäulenverriegelung
EMF Elektromechanische Feststellbremse Elektromechanische Feststellbremse
EML Elektronische Motorleistungs Regelung Elektronische Motorleistungsregelung
EPB Elektrische Parkbremse Elektrische Parkbremse
EPROM Erasable Programmable Read Only Memory Speicherchip (Steuergerät)
EPS Electronic Power Steering elektrisch unterstützte Lenkung
ESA Electronic Suspension Adjustment Elektronische Dämpfereinstellung
ESD Electrostatic Discharge Elektrostatische Entladung
ESL Einschichtlackierung Lackierung
ETC Electronic Toll Collection Autobahngebührenregistrierung
ETK Elektronischer Teilekatalog Elektronischer Teilekatalog
EWB Extended Wheel Base Langversion
EWS Elektronische Wegfahrsperre Elektronische Wegfahrsperre
FAKRA Normenausschuss Kraftfahrzeuge Fachnormenausschuss Kraftfahrzeuge
FBD Fernbedienung Fernbedienung
FCD Floating Car Data Echtzeitverkehrsleitsystem
FCKW Fluorchlorkohlenwasserstoff -->R12 Fluorchlorkohlenwasserstoff
FDC Fahrdynamik Control Antriebssystem
FG Funktionsgruppe Funktionsgruppe
FG -> Ab Fahrgestellnummer Fahrgestellnummer (VIN)
FIBAS Farbbild-Austast Sychronsignal Farbbildsignal
FLA Fernlichtassistent Fahrerassistenzsystem
FRM Fussraum Modul Steuergerät für Karosseriefunktionen
FRU Flat Rate Unit Arbeitswert
FSC Freischaltcode Freischaltcode
FU Frisch-/Umluft Luftaustritt
FZD Funktionszentrum Dach Karosseriesteuergerät
Funk Funkfernbedienung Spiegelfunktion
GAL Geschw.abh.Lautstärkeregelung Geschwindig.abhängige Lautstärkeregelung
GM Grundmodul Grundmodul
GOeK Getriebeölkühler Getriebeölkühler
GPS Global Positioning System Navigationssystem
GSM Global System for Mobile Communication Kommunikationssystem
GTO Gate Turn Off Garagentoröffner
GWS Gangwahlschaltung Automatik
H2 Wasserstoff Wasserstoff
HA Hinterachse Hinterachse
HAG Hinterachsgetriebe Hinterachsgetriebe
HC Heading Control Assistenzsystem
HD Heavy Duty Erschwerter Einsatz
HDC Hill-Descent-Control Bergabfahrhilfe
HF Hochfrequenz Hochfrequenz
HFM Heissfilm-Luftmassenmesser Luftmassenmesser
HG Hauptgruppe Hauptgruppe
HP High Performance High Performance
HS Handschaltung Handschalter
HSG Hör-Sprech-Gerät Gegensprechanlage
HSR Hinterachs-Schräglaufregelung Fahrwerk
HU'D Head-Up Display Head-Up Display
HV High Voltage Hochvolt-System
HWS Hinweisschild Schild
I Übersetzungsverhältnis Übersetzungsverhältnis
I-ABS Integral ABS Antiblockiersystem
IBOC In Band On Channel Digitalradio USA
IBS Intelligenter Batteriesensor Batteriesensor
ICM Integrated Chassis Management Integrated Chasis Management
ICOM Integrated Comminication Optical Module Integrated Comminication Optical Module
ICS Indoor communication system Indoor communication system (Marketing)
IHKA Integrierte Heiz-Klima-Automatik Integrierte Heiz-Klima-Automatik
IHKAF Integrierte Heiz-Klima-Automatik + MF Integrierte Heiz-Klima-Automatik + MF
IHKR Integrierte Heiz-Klima-Regelung Integrierte Heiz-Klima-Regelung
IHKRF Integrierte Heiz-Klima-Automatik + MF Integrierte Heiz-Klima-Automatik + MF
IHR Integrierte Heizungs-Regelung Integrierte Heizungs-Regelung
IHRF Integrierte Heizungs-Regelung plus MF Integrierte Heizungs-Regelung plus MF
IKT Informations-/Kommunikationstechnologie Informations-/Kommunikationstechnologie
IMS Instant Mobility System Instant Mobility System
ISA Innensternangriff Schraubtechnik
ISIS Integrated Service Information Server HW-Basis für ETK und Servicedaten
ISO Isolationsüberwachung Isolationsüberwachung
ISPA Integrated Service Processes Application Werkstattplanungssystem
ITS Inflatable Tubular Structure Kopfairbag
Indi. Individual Individual
JCW John Cooper Works JCW
JPT Junior Power Timer Steckkontaktsystem
KA Klimaanlage Klimaanlage
KAT Katalysator Katalysator
KBA Kraftfahrt-Bundesamt Kraftfahrt-Bundesamt
KG Kurbelgehäuse Kurbelgehäuse
KKB Komplettkabelbaum Komplettkabelbaum
KM Kühlmittel Kühlmittel
KSK Kundenspezifischer Kabelbaum Kundenspezifischer Kabelbaum
KW Kilowatt Kilowatt
KaFAS Kamerabasierende Fahrerassistenzsysteme Assistenzsystem
Kompass Digitale Kompassanzeige Spiegelfunktion
L Länge Länge
LAZ Lagerzeit Lagerzeit
LBV Lehnenbreitenverstellung Lehnenbreitenverstellung dynamisch
LCI Life Cycle Impulse Modellüberarbeitung
LCPA LIN-Controlled Power Amplifier Leistungsverstärker
LDM Längsdynamik-Management Fahrdynamikregelung bei Allradfahrzeugen
LED Light Emitting Diode Leuchtdiode
LH Left Hand Linke Seite
LHD Left-Hand-Drive Linkslenker
LIN Local Interconnection Network Vernetzung von Steuergeräten
LOM Licht-Optik-Modul Batterieüberwachung
LRR Long Range Radar Radarsystem
LSC Leichtbauweise-Stahl-Compact Leichtbauweise
LSK Laststrom-Kontakt Stecksystem
LVDS Low Voltage Differential Signal Schnelle Datenübertragung
LVM Lagerverpackungsmenge Lagerverpackungsmenge
LWL Lichtwellenleiter Lichtwellenleiter
LWR Leuchtweitenregulierung Leuchtweitenregulierung
M Manuelles Getriebe Schaltgetriebe
MAK Modular Automobil Kontakt Stecksystem
MAM Mindestabnahmemenge Mindestabnahmemenge
MASK Multimedia Audio System Kontroller Multimedia-Audiosystem-Kontroller
MCON Multicontakt Stecksystem
MDK Miniatur Doppelflachfeder Kontakt Steckkontaktsystem
MF Mikrofilter Mikrofilter
MFL Multifunktionslenkrad Multifunktionslenkrad
MID Multi Information Display Multiinformationsdisplay
MLK Mini Lamellen Kontakt Kontaktstecksystem
MOST Media Oriented System Transport Bus-System
MOeK Motorölkühler Motorölkühler
MPQ Micro-Power-Quadlock Stecksystem
MQS Micro-Quadlock-System Stecksystem
MSA Motor-Start/Stop-Automatik CO2 Massnahme
MULF MOST-univers.Lade-/Freisprecheinrichtung Lade-/Freisprecheinrichtung
MÜ Modellüberarbeitung Modellüberarbeitung
NOX Stickoxid Abgas
NSD Nachschalldämpfer Nachschalldämpfer
NVC Night Vision Camera Nachtsichtkamera
NoS No Stock Teil zentral nicht lagernd.
OBD On-Board-Diagnose Diagnose-System
OCS Outdoor communication system Outdoor communication system (Marketing)
OGW Onboard-Diagnostic-Gateway Diagnoseanschluss
PAV/PAX Pneu Acrosach Vertical Reifenstützring
PD Paris-Dakar Ralleyveranstaltung
PDC Park Distance Control Einparkhilfe
PEB Power Electonic Box Leistungselektronik
PEU Power Electronics Unit Stromverteiler
PGS Passive Go Steuergerät Fahrererkennung
PI Produktinformation Produktinformation
PLATO Planungstool Planungstool für Zubehör
PLCD PermanentmagnetLinearContactlessDisplace Sensor Leergaserkennung
POI Points of Interest Orte von Interesse
PT-Schr. Markenname Gewindeformende Schraube für Kunststoffe
PTC Positive Temperature Coefficient Thermistor
PTT push to talk Spracheingabe
QL Quer- und Längsdynamik Fahrdynamikregelung
R Rechtslenker Rechtslenker
R12 FCKW-haltiges Kältemittel FCKW-haltiges Kältemittel
R134A FCKW-freies Kältemittel FCKW-freies Kältemittel
RAL Reichsauschuss für Lieferbedingungen Farbnorm
RDC Reifen-Druck-Control Reifendruckkontrolle
RDS Raddrehzahlsensor Raddrehzahlsensor
REP Reparatursatz Reparatursatz
RFK Rückfahrkamera Rückfahrkamera
RFT Run Flat Technologie Bereifung mit Notlaufsystem
RH Right Hand Rechte Seite
RHD Right-Hand-Drive Rechtslenker
RHT Retractable Hardtop Hardtop versenkbar
RKLE Rundumkennleuchte Rundumkennleuchte
RLS Regen-/Lichtsensor Beleuchtung
ROC Roll Over Control Überrollschutz
ROZ Research-Oktanzahl Kraftstoffqualität
RPA Reifen-Pannen-Anzeige Reifen Pannen Anzeige
RS Regensensor Regensensor
RSC Runflat System Component Bereifung mit Notlaufsystem
RSE Rear Seat Entertainment Nachrüstsatz Rear Seat Entertainment
RSI Rear Seat Infotainment Nachrüstsatz Rear Seat Entertainment
RWS Richtwinkelsatz Karosserie Richtsystem
RZV Ruhende Zündspannungsverteilung Einzelzündspulen
SA Sonderausstattung Sonderausstattung
SAF Synthetic Axle Fluid Hinterachs-Getriebeöl
SAP SIM Access Profile Übertragungsprotokoll Bluetooth
SAV Sports Activity Vehicle Sports Activity Vehicle
SAW Shielded access to Wireless LAN Shielded Access to Wireless LAN
SAZ Sonderausstattung Zubehör Seriennahes Zubehör
SBA Sensotronic Brake Actuation Bremssystem für Hybrid
SBK Sicherheitsbatterieklemme Batterieklemme
SBT Service-Information BMW Technik Service-Information Technik
SCA Soft-Close-Automatik Soft-Close-Automatik
SCR Selective Catalytic Reduction Abgasreinigung Stickoxide
SDARS Satellite Digital Audio Radio Service Satellitenempfang
SDB Sicherheitsdatenblatt Sicherheitsdatenblatt
SG Steuergerät Steuergerät
SGS Sitzintegriertes Gurtsystem Sitzintegriertes Gurtsystem
SI Service-Information Service-Information
SIP Schulungs- und Informationsprogramm Schulungs- und Informationsprogramm
SKR Sommerkomplettrad Sommerkomplettrad
SLK Sensor Lamellen Kontakt Kontaktstecksystem
SLP Stromlaufplan Stromlaufplan
SLS Sekundärluftsystem Sekundärluftsystem
SMB Subminiatur Version B Stecksystem Antennenleitungen
SMG Sequenzielles Manuelles Getriebe Sequenzielles Manuelles Getriebe
SML Seitenmarkierungsleuchte Seitenmarkierungsleuchte
SOP Start of Produktion Beginn des Serieneinsatzes
SPEG Smart Power Electronics Gateway Steuergerät für Karosseriefunktionen
SRA Scheinwerferreinigungsanlage Scheinwerferreinigung
SRD Supply and Replenishment Dealership Teilenachschubsystem
SRP Service-Reparatur-Pakete Service-Reparatur-Pakete
SRR Short Range Radar Radarsystem
SRS Safety Restraint System / Airbag Safety Restraint System / Airbag
SRT Sun Reflective Technology Infrarotreflektierendes Leder
SSR Sonnenschutzrollo Sonnenschutzrollo
STV Sitztiefenverstellung Sitztiefenverstellung
SW Schlüsselweite Schlüsselweite
SZ Sonderzubehör Sonderzubehör
SZL Schaltzentrum Lenksäule Schaltzentrum Lenksäule
TCU Telematics Control Unit Telematics Control Unit
TI Technische Information Technische Information
TIS Technisches Informations System Technisches Informationssystem
TLC Time to Line Crossing Fahrerassistenzsystem
TMC Traffic Message Channel Verkehrsfunk
TPA Telematik Plattform Accessory Telematik Plattform Accessory
TÜV Technischer Überwachungs Verein Herstellerbescheinigung
UERSS Überrollschutz Überrollschutz
UG Untergruppe Untergruppe
ULF Universelle Lade- u. Freisprecheinricht. Universelle Lade- u. Freisprecheinricht.
UPE Unverbindliche Preisempfehlung Unverbindliche Preisempfehlung
USB Universal Serial Bus Universelle PC Schnittstelle
USIS Ultraschall Innenraumschutz Innenraumschutz
VA Vorderachse Vorderachse
VDC Vertical Dynamic Control Fahrwerkstechnik
VDD Ventildeckeldichtung
VDM Vertikaldynamik Management Fahrdynamikregelung bei Allradfahrzeugen
VF Verkehrsfunk Verkehrsfunk
VHT Versenkbares Hardtop Hardtop versenkbar
VICS Vehicle Information&Communication System Fahrzeuginformationssystem
VIN Vehicle Identification Number Fahrgestellnummer (VIN)
VMS Vehicle Management System Steuergerät BEV
VOC Volatile Organic Compounds Flüchtige organische Lösungsmittel
VVM Vorverpackungsmenge Vorverpackungsmenge
VVT Variabler Ventiltrieb Variable Ventilsteuerung
WAPU Wasserpumpe Wasserpumpe
WBA Warnblinkanlage Warnblinkanlage
WKR Winterkomplettrad Winterkomplettrad
WSA Wechselsprechanlage Wechselsprechanlage
ZBE Zentrales Bedienelement iDrive Controller
ZFE Zentrale Fahrzeug-Elektronik Steuergerät
ZKD Zylinderkopfdichtung
ZKE Zentrale Karrosserie-Elektronik Steuergerät für Karosseriefunktionen
ZKW Zizala Karl Wien Lieferant Lichtsysteme
ZV Zentralverriegelung Zentralverriegelung
ZWSL Zweischichtlackierung Lackierung
MfG,
Norbert
Geändert von nordberg (06.10.2011 um 21:17 Uhr).
Grund: Teil 2 ergänzt
