Alt 27.12.2002, 19:14   #11
schnitzer
inaktiv, keine gültige e-Mail
Fahrzeug: M5 3,8 E34
Dome: That will be perfekt!!!
Erich: It´s two separate things I mean. First the "spoilerecken" and then the "Lüfter" for the air which comes into the cars inside, if you know what I mean? I have already heard the price hear in Sweden and I want to compare the swedish price and with the german.
//Schnitzer
schnitzer ist offline   Antwort Mit Zitat antworten
Alt 27.12.2002, 19:32   #12
Orginal gepostet von schnitzer
//Schnitzer
Schnitzer,
I do not have any prices here. But just as a reference please check the following discounters in USA
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www/bimmerparts.com
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) http://www.bmwpartstore.com
I checked one of them: Fan Blade 55 $, Fan Clutch (Behr) 103,04 $
Mostly the parts are with pictures. But they have their own parts numbers, so difficult to compare. On the other hand you have to klick type and production year. Not all parts are available. Sometimes they also have options, OEM parts, or substitutes. For example the "Schwert" is available from Behr but also another maker, which is cheaper. Maybe this helps you to compare. The advantage is that you can pay by credit card and they ship worldwide with FedEx.
Alt 27.12.2002, 20:42   #13
schlitzohr730il
Fahrzeug: E32 730il V8 + Suzuki 750GSXF
hello schnitzer
:zwink
I have read your Posting´s,
I will went to BMW Cuntz Speyer. Then i will ask if it is possible to send parts to sweden.
I have looked in the E** for your "Spoilerecken" the price without discount is 47.65 €
I will notify you tomorrow evening.
Greetinx.
Guenni
ps. i have looked in my emails for the discount rates, the rate for this price is 20%!
[Bearbeitet am 27.12.2002 von schlitzohr730il]
schlitzohr730il ist offline   Antwort Mit Zitat antworten
Alt 27.12.2002, 23:01   #14
Standard @Guenni
dann frag bitte auch sofort nach wie es mit Versand nach Japan aussieht. Duerfte eigentlich kein Problem sein. Wenn's nicht so eilt, Pakete mit Luftpost. Fuer Luftfrachten (schwere Sendungen) haette ich einen Spediteur, da wir eh jede Woche 1-2 Tonnen an Ersatzteilen nach hier fliegen. Aber das kommt hoffentlich nicht so oft vor
Rechnung muesste dann auf meine Adresse in Japan ausgestellt werden, damit keine MWST zu zahlen ist. Falls notwendig, kann ich mir die Rechnung auch hier von der deutschen Botschaft abstempeln lassen als Ausfuhrnachweis. Ist der uebliche Weg, falls man keine Frachtpapiere hat bzw Teile in Deutschland kauft und ausfuehrt. Dann wird die MWST zurueckerstattet. Beim Mitnehmen kann man sich die Rechnung am Flughafen vom Zoll als Ausfuhrnachweis abstempeln lassen gegen Vorzeige der Ware im Zollbereich.
Alt 27.12.2002, 23:13   #15
schnitzer
Schlitzohr730il: Thank you! It´s great to talk to people who can help me when my german language is not so good. It would be great to buy parts from Germany. I have heard people in Sweden who have bought BMW-parts from Germany and they have been very safisfied with the parts and especially the good service the germans have, and the behavoir. I think in Sweden, the service is not so good, the people are not so serviceminded, that´s bad.
Is it 20% of all parts? Some people in Sweden says that I can´t buy parts from Germany because the BMW in Sweden don´t like it, but I think that´s wrong, we are member of the EU so it should be possible.
Thank you again!!!!
Thank you again!!!!
Erich: Thanks for the links. I heard the price for the "Lüfter" in Sweden, it costs 2000 SEK, and that is ca 220 Euro with the exchangerate in Euro 9,10. I think it´s a lot of money. Sweden is "Schweinteuer"!!!!!!
//Schnitzer
Alt 27.12.2002, 23:18   #16
schnitzer
Sorry, there has been two same messages for you!!!
//Schnitzer
Alt 27.12.2002, 23:26   #17
my pleasure Schnitzer.
As far as I understood, the discounts for the parts vary from the source depending on the discount they get.
But in any case it will be cheaper than the standard customer in Germany can buy.
Of course your dealers in Sweden do not like that people buy somewhere else cheaper.
But EU is there, if they like it or not.
But keep an eye on the prices in USA, sometimes it might even be cheaper there. Exchange rate, dealer discounts etc.
Many makers have different discounts for their dealers, depending on the annual amount the buy.
So that means with the Luefter you can already save 160 Euro, if you buy in the States. Shipping by FedEx should not be that much.
Best regards
[Bearbeitet am 27.12.2002 von Erich]
Alt 28.12.2002, 02:07   #18
Big M
Benutzerbild von Big M
Fahrzeug: G12-750 Li xDrive 11/2015;850i 10/93; E36 328i Cabrio 11/98;X5 4,4 E53 06/2004; K1300R 04/11; VFR 800 01/99
Habe im Frühjahr etwa 37,-EUR für eine bezahlt.Vielen dank dem netten Hasen.
Big M ist offline   Antwort Mit Zitat antworten
Alt 28.12.2002, 12:31   #19
schnitzer
Erich: I didn´t find any "spoilerecken" or "Lüfter" from the two links you gave me, but I think it can be good to have the choise to buy parts from the US. But it must be cheaper to buy from Germany than in Sweden. I have to install the ETK and see if I find the two parts then I can show you them and then you know exactly what parts I mean.
//Schnitzer
Alt 28.12.2002, 13:03   #20
//Schnitzer
Schnitzer: The Spoilerecken are not available from the 2 links in USA. They usually offer only main wear parts.
As for Luefter I think you mean the fan blade in front of the radiator, which is driven by the visco clutch ? That one was on bimmerparts.com under cooling systems, p/n G5050-28211 at $ 55,25. Or do you mean the radiator=Kuehler?
Anyway I think it is better somebody shows the spare parts * drawing with number, so it is easier to understand.
Anyway, yours is a 750i from 1991.
Do you now have the chassis number last 7 digits? Then somebody can check it.
Was kostet ein "blanko" Schlüssel für den E65? LEXX BMW 7er, Modell E65/E66 16 03.04.2009 08:05
Was kostet ca. Zündkerzen wechseln beim E38 750i? KJ750IL BMW Service. Werkstätten und mehr... 1 17.04.2004 19:22
Hilfe-was kostet TeileNr. 34 11 1 164 082 - 33 Euro? R1200rs BMW 7er, Modell E38 3 12.02.2004 10:47
Tank leckt - was kostet der Spass? Cruiser BMW 7er, Modell E38 7 27.03.2003 09:46
Alle Zeitangaben in WEZ +1. Es ist jetzt 01:29 Uhr.
