Alt 29.11.2020, 02:49   #6
Andrew1Q
Fahrzeug: BMW E32-735i (02/1990)
If you look at picture of Pump Suction plug is the same channel as Cooler Return line witch goes to the radiator cooler and Cooler Out line witch goes to the radiator cooler is the same channel as T/C Release and "A" Clutch. And Pressure Line plug can be used for a Gauge to check pressure in a system so as T/C release and "A" Clutch one of those ports can be check too for pressure as well. Is that make sense or not ? Instead to mess with cooler lines from the radiator. If to hook up line from machine to push fresh oil in to transmission to use Pump Suction Plug and to take it out used oil from the transmission to use T/C Release plug or "A" Clutch plug. What plugs would you choose "A" Clutch plug or T/C Release plug to remove oil oil from the transmission ?
Dateityp: jpg oil pump housing.jpg (17,6 KB, 21x aufgerufen)
Geändert von Andrew1Q (29.11.2020 um 02:59 Uhr).
Andrew1Q ist offline   Antwort Mit Zitat antworten
Automatikölwechsel 4HP22 incl. Wandler? hemmer.tom BMW 7er, Modell E32 21 13.11.2006 18:52
Automatikölwechsel, 5Gang, Ölmenge auch ohne Überlauf?! niceuwe BMW 7er, Modell E32 0 20.04.2004 11:20
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:09 Uhr.
