Alt 09.04.2009, 03:40   #15
Getriebe ueberfuellen soll auch sehr problemreich sein, deshalb hat man wohl auch den Peilstab entfernt, hier mal kopiert:
Automatics with No Dipsticks
According to automobile manufacturer research, a certain percentage of automatic transmission failures are caused by over-filling and/or using the incorrect transmission fluid. It is important to remember to NEVER over-fill the transmission assembly and to ALWAYS use the recommended transmission fluid. To discourage over-filling, some vehicle manufacturers have eliminated the dipstick on the transmission. Unfortunately, this also makes it hard to tell if the fluid level is low.
On automatic transmissions that do not have a dipstick to check the fluid level or add fluid, a fill plug is usually located on the left side or right side of the transmission. On some, there may also be a drain plug on the bottom of the transmission.
To check the fluid level, the transmission must be warm and the vehicle must be parked on a level surface or raised on a lift. Jacking up the front wheels will tilt the vehicle and give an inaccurate indication of the fluid level. Therefore, all FOUR wheels must be raised off the ground and the vehicle must be properly supported by four jack stands. NEVER crawl under a vehicle unless it is safely supported by jack stands.
When the fill plug is removed, some fluid should dribble out of the hole if the fluid is at the proper level (flush with the bottom of the fill plug hole). If no fluid comes out, add fluid to bring it up to the level of the hole.
Externer Link (&Ooml;ffnet in neuem Fenster, der Forumsbetreiber distanziert sich vom Inhalt extern verlinkter Seiten.) Automatic Transmission Fluid
Motorraum: Ölmessstab Lapachon BMW 7er, Modell E38 11 16.06.2008 22:07
Motorraum: Öl kommt beim Rausziehen des Ölmessstab raus pm-disco BMW 7er, Modell E38 32 03.06.2008 20:35
Ölmessstab am e65 - es gibt ihn wirklich esau BMW 7er, Modell E65/E66 8 08.02.2008 20:03
Motorraum: Ölmessstab andy34 BMW 7er, Modell E38 28 18.04.2006 13:12
V12 drückt Öl über den Ölmessstab raus.... JPM BMW 7er, Modell E32 13 12.12.2004 01:18
Alle Zeitangaben in WEZ +1. Es ist jetzt 06:29 Uhr.
